Crank/torque tube
Old Aug 11, 2023 | 08:17 PM
361vette's Avatar
361vette
Cruising
Default Crank/torque tube
Has anyone experience torque tube slightly pushing thrust bearing? If so what will cause this.
Ever since new built, this is the third time the crank has been pushed.
I have the stock transmission
circle d converter
upgraded torque tube couplers
416 built
it’s in a 2014 stingray
anything will help
Old Aug 12, 2023 | 08:04 AM
AnotherNorskie's Avatar
AnotherNorskie
There have been a few threads on this recently; there is a procedure for measuring where the auto transmission should be clamping the TT (M7's have floating splines so not an issue). It seems if this keeps happening, is it with the same tech or shop? Maybe find someone better qualified to do the work?
Old Aug 13, 2023 | 06:16 PM
RonC7's Avatar
RonC7
Here's the Chevy procedure:
https://www.corvetteactioncenter.com...dure-1313.html
Ron
Old Aug 14, 2023 | 07:48 AM
Tinkertech's Avatar
Tinkertech
Sounds like the locking collar is slipping.
Old Aug 14, 2023 | 02:25 PM
361vette's Avatar
361vette
Cruising
Originally Posted by RonC7
appreciated Ron, that’s some really good info. Did something like this happened to you as well?
Old Aug 14, 2023 | 02:26 PM
361vette's Avatar
361vette
Cruising
my mechanic said no 🤷🏽‍♂️
Old Aug 14, 2023 | 02:43 PM
RonC7's Avatar
RonC7
Thankfully, I have had almost no issues with my 2014 or current 2019. There were several threads on torque tube failures and subsequent engine issues in the early years of the C7. I just have an engineer's interest in the car and tend to bookmark interesting threads or good information.
Ron
To Crank/torque tube
