Magnaride technical question
I am trying to decide if I should go with a DSC controller or just swap to passive dampers that I can just valve to what I want. It would be nice if I didn't have to swap the shocks a bunch of times if I can help it.
He is not always active on the forum but he has been very helpful with in-depth technical suspension discussion in the past. You may do better by DMing him. You might also try speaking to the people at DSC, as they have been using their controller to tune the OEM MSRC dampers for several years now.
https://www.autoevolution.com/news/j...ry-204922.html
I understand why I would make a change but what I want to make sure is that I understand how I would set the knee speed, or that I understand how I would test how the shock would blow off. All this to say, is it worth my time messing with a DSC controller, or if it would be easier to go with my own valved passive damper.
Yes.
Yes.
Re: Your original question - It sounds like you could end up spending a lot of time, energy, and unnecessary money trying to achieve your desired goals with the OEM shocks and DSC controller, unless you are committed to exploring the full potential of the OEM shocks.
Disclaimer: I am not an engineer or a chassis tuner.
My understanding is as follows: C7 MSRC shocks are mechanically very simple, with a single piston with fixed bypasses drilled through it. If the shock were filled with standard oil, the shock would have equal damping on compression and rebound. All of the shock tuning is accomplished by electromagnetically varying the viscosity of the shock fluid, including simple compression and rebound (in response to changes read by the ride height sensors). Beyond using the baselines for each drive mode, the computer dynamically adapts the shock fluid viscosity in response to throttle/brake/steering inputs, G-Force readings, wheel speed, and, possibly shock velocity.
I would ask DSC what granularity you can tune stiffness vs. shock velocity with their controller. If you are able to finely tune based on shock velocity, you would be able to set your low speed damping, high speed damping, knee speed, and blow off as you please.
Re: Blow off - are you trying to dyno the shock at lowest possible viscosity? I do not know that anyone has that data, other than maybe DSC/Tractive if they baselined the OEM shocks when designing the RT and RTs shocks. I am not sure how you would be able to max out softness without a DSC controller, and I'm not entirely sure how many other parts of the system you would have to wire in to make it work. This may only be possible via trial and error, tested on the car at the track.
All of this is to say that, for the result you are trying to achieve, a high end adjustable shock of your choice may be your best option, even if initially more expensive.
One thing to note is that the Z06/Z07 shocks are mechanically stiffer than the all other MSRC shocks. Per Jim Mero, when he and the other chassis engineers were developing the ZR1, they discovered that they could achieve the same level of stiffness with a much wider range of adjustability using the non-Z07 shocks. Accordingly, all ZR1s, including ZTK package cars, have the softer non-Z07 shocks installed.
I'm sure you already knew most, if not all, of what I've provided, but I hope some of it was helpful and I would be very interested to see what kind of complex damping is possible with the factory equipment.
All pistons have whatever bypasses they have, what I am worried about is free bleed and bleed control. I know how I am achieving that with a standard damper. I have not messed with MRC shocks. I have with other magnetically controlled shocks, like PASM.
Only if the piston configuration isn't limited to a speed lesser than what I would choose. Example; if the piston begins its blow-off at 2 inches per second I cannot change that unless I have control over bleed and or pre-load.
I like really digressive blow off, so I would want to understand how the MRC shock does that, 'how' digressive can I get. What are the limitations? The DSC velocity table is just an % offset the issue is an offset of what measurement? Say I plug in +15% low speed compression, 15% of what? Baseline is not a meaningful number and I do not like guessing. That is to say if I want a specific amount of damping I'd like to be able to pick a critical damping ratio and then adjust based on my choice.
That statement by itself does not make much sense. Between tyres, springs, and the shock spring rate, there is a total stiffness in the system. The shock is the only item that can be for example sake infinitely adjustable. It would go without saying that you can achieve a stiffness with lots of adjustability.
Although... this does lead me to believe that the MRC shock is limited to a specific configuration and as a result the range of useful adjustments is limited as well.
My note on the Z07 dampers being "stiffer" is directly from Jim Mero. The piston has physically smaller bypasses, as they were concerned that achieving higher low speed damping (stiffer) necessary for the additional aero and Cup2 grip of the Z07 by decreasing the viscosity of the MR fluid alone would result in unnatural ride and handling, so they spec'd a physically tighter damper, which, by its nature, mechanically reduced maximum shock velocity, limiting how "soft" they could make tune the damper. This turned out to be unnecessary, so when they were designing the ZR1, they went with the original damper.
The below video shows an MR damper off of a 2016 Suburban being cut open, and you can see the simplicity of the piston and bypass for yourself. As I understand, the Corvette damper is no different.
Not quite. Forget magnaride shocks for a moment. Standard shocks have all sorts of valving, blowoff etc. But they also have oil which has a certain viscosity. Let's consider just pumping oil through an orifice. At any given temperature, and oil viscosity, you can only vary orifice size so much before you lose control. Too small an orifice and the shock essentially locks up. Too large and it pumps a lot of oil but has no effect on damping. My thinking is that for any given assembled shock there can only be a certain range of adjustment available. I think this applies to mag ride too. We know that the oil viscosity is changed electrically, but it is still an oil. So it can only get so thin which means it can only get so soft. IE, if you have a given orifice that thin oil could get to a point where it runs through the orifice w/ so little resistance that there is no damping. Then you realize you have no soft end control w/ that orifice size so you make it smaller. Now you have some damping w/ the thinnest oil, but now also, you are going to reduce max hard end damping before it locks up. So 'infinitely adjustable' can't apply to one assembled shock. It could apply to a series of shocks all fitting the same application. Or it can apply to a high end shock that can be sent back to a service center to be revalved.
Mrc not having any sort of valve stack would mean zero bleed control which means we are more or less stuck with what the piston can generate through fluid of varying viscosity and there is essentially no bleed control. The viscosity will change how linear or progressive force generation is but without valving there will be no significant blow off. We could get a digressive curve for sure just not a very aggressive blowoff.
Otherwise, yes the answer is to revalve a shock for a particular performance profile. I have a shock dyno and tools in my garage and I revalve my own shocks. I was hoping to see what I can do with mrc shocks but at this point will go with either penskes or qa1's.
So, the bypass you speak of is not like a bypass in a disc or deflected disc passive damper. There is a gap in the magnetic ride piston that allows for some low-speed mechanical damping. Actually through the entire shock velocity, there is mechanical damping but there is always PWM running, even at zero velocity.
I understand what you are speaking of when you talk about the knee in the curve creating a digressive shape. But there are so many algorithms (40'ish) running, you can't just treat it like a passive damper.
Although I will say that with several of the algorithms I clearly digressed the amount of authority through pulse width modulation as a shock velocity increased.
There are logarithm for the body motion controls, heave, pitch, and roll. There are wheel logarithms, and there handling algorithms. There are also algorithms that scale damping with vehicle speed. Even though they are different algorithms, they do interact quite a bit so balancing them all out is a bit daunting but very rewarding.
I do remember we did have curves of zero current at shock velocities from .0625 m/s to 3 m/s.
I am curious as to what year car and what model you have? And if it is 7th generation, do you have the upgrade that I developed but before I retired?
Personally, I have seen the DSC software and it's a bit archaic. There are a lot of deficiencies. I'm curious dynamically what you are looking for.
Thanks, Jim
Thanks, Jim
I have a C7 Grand Sport. I'm not sure if it has the upgrade, it is on my to do list to find out. I happen to agree with your opinion on the DSC software, I have yet to buy into their system (not in any way saying others shouldn't). I enjoy the DIY challenge to things and so was considering it just for the experience / adventure.
So far as dynamics, traditionally I tune passive dampers so that I have as little cracking force as possible. Mostly I achieve that through adjusting gas pressure and understanding I will have a relatively large amount of hysteresis. On the flip side, if I run a lot of bleed then I will deal with a harsher cracking force and run more gas pressure in order to achieve more high speed compression.
On non aero cars I tend to like equal or slightly compression bias in the front and a slight rebound bias in the rear. I do not like to ride on the bump rubbers, rather use them to decelerate the wheel. So I tend to avoid 2-3:1 rebound to compression to avoid significantly jacking down.
Here is an example from my gt350. I started with a force matched setting (think zero point shock) so that I can use a high speed bleed circuit to give me rebound adjustment throughout the stroke. (area under the curve)
Front: McPherson strut
66lbs/in Critical
Damping rate of 0.62
41lbs/in @ 1.0 IPS
