Check engine
Old Jan 23, 2024 | 10:51 AM
vabadger's Avatar
vabadger
Default Check engine
I replaced Original battery in my 2017 Z51 Stingray. Now the check engine light is on. What to do to clear that?
Old Jan 23, 2024 | 12:23 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You can try disconnecting the battery again…if not I’d put a scan tool on it and see what DTC may be stored !!
Old Jan 23, 2024 | 02:16 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Check the thin black wire is attached to negative terminal and not damaged.
Old Jan 23, 2024 | 10:19 PM
Try both of the above if needed. If code still remains, get the car looked at by a qualified Corvette tech.
Old Jan 24, 2024 | 01:51 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Why not start with the obvious and connect a scanner to read the code(s)? Any auto parts place can do that if you don't know anyone with a scanner.
To Check engine
