3D Printed Cold Air Intake
Old Feb 28, 2024 | 04:22 PM
shaladdin's Avatar
shaladdin
Impressive print and enclosure! One thing I was thinking you could do is wrap the ABS in heat shielding, inside and out, if PC proves to be too difficult/annoying to print.
If you want to be fancy, you could also consider skinning in carbon fiber or using what was printed as a mold for a carbon fiber inlay.
Regardless, excited to see what you do next!
Old Feb 28, 2024 | 04:59 PM
hiltsy855's Avatar
hiltsy855
Great ideas! The CF thing has me thinking LOL. I used DEI heat shield on my Camaro and it's easy to work with.
Right now I'm printing with a really nice filament I found on
Amazon Amazon
that is a blend of PC and PETG. It's supposed to be tough & heat resistant like PC but print like PETG. The first piece printed great, I'm really impressed so far. Much easier to print than ABS: little warping, good adhesion, and it's supposed to withstand 110 deg. C (230 deg F). I printed with the extruder at 255, which is about the max for my Sidewinder, but so far so good.
Thanks again for the help! Cheers!
Old Mar 9, 2024 | 09:34 PM
hiltsy855's Avatar
hiltsy855
I have all the pieces printed in polycarbonate (PC). As a test I submerged a PC section in boiling water for 10 minutes and it was unaffected. I'll get the PC pieces installed at some point, but the ABS parts are working fine for now with outside temps in the 60s.
Old Jul 13, 2025 | 05:17 PM
Novajoe1966's Avatar
Novajoe1966
1st Gear
Would you share the STL file? I would like to see if I can modify it for a ZL1. your design looks great.
Old Jul 15, 2025 | 02:13 PM
hiltsy855's Avatar
hiltsy855
It looks like you don't have enough posts for me to send you a Private Message.
Old Jul 15, 2025 | 07:15 PM
drchewchew's Avatar
drchewchew
Are you planning on sell these or the STL file? Or sharing the file with other members?
Old Jul 15, 2025 | 09:53 PM
hiltsy855's Avatar
hiltsy855
I'm happy to share the .stl or solid model files.
FYI - I ran the printed parts for a few months but after several high-heat cycles the areas where I clamped the pieces for flex couplings started to collapse. So I re-installed the stock pieces and have run it that way all this year. As was mentioned previously I think these parts need to be printed with nylon filament to work like the factory pieces. Another idea I had is to build the pieces with a groove that I could embed a stainless band to keep the pieces from collapsing. Or as shalladin mentioned use 3D printed parts as a mold for carbon fiber. I just haven't had time to tinker with it.
Old Nov 4, 2025 | 10:36 AM
wormy267's Avatar
wormy267
3rd Gear
Default Stl
Is there a link for the file looks awesome !!!!
Old Nov 13, 2025 | 10:12 PM
frankbicknell's Avatar
frankbicknell
Me too please.
Old Nov 13, 2025 | 10:22 PM
frankbicknell
A couple of ideas. How about reinforcing with an aluminum ring or some other material. Maybe thicker print at the joints. What about painting the parts with high temperature paint?
Were the parts that collapsed printed with PLA? I printed a few parts to be used on my boat in PETG. They were in the sun for most of the season on the upper helm where it gets very hot. There is no distortion in the parts.
Old Nov 13, 2025 | 10:40 PM
hiltsy855's Avatar
hiltsy855
Just PM me your email address and I'll send you the files.
The prototype pieces were printed in PLA for fitment only. I tried PC and ABS but both got soft from underhood heat. My latest idea was to use a stainless ring (like from a band clamp) to reinforce the joints. As I mentioned before I just haven't had time to mess with it.
Old Nov 14, 2025 | 10:55 AM
smitty2919's Avatar
smitty2919
Neat project. I'd be curious to see if there were any gains from this design of intake tube tested back to back on a dyno. Trey to measure the pressure differentials and reading MAP kPa differences to see what level of restriction there is in the system.
Some things are an experiment just to tinker, but the better ones are when they actually prove fruitful. These are the projects I like to get into.
I would agree to find an aluminum or steel thin-walled ring that can be inserted and glued into the ID of the tube join into a stepped recess to strengthen the openings. Keep it going!
Old Nov 14, 2025 | 11:24 AM
  #33
wormy267's Avatar
wormy267
3rd Gear
worm267@gmail will not let me message you
Old Nov 15, 2025 | 03:14 PM
  #34
hiltsy855's Avatar
hiltsy855
Guys,
I need some time to convert the files to STL. Sorry. I can pack-n-go the SolidWorks files if you can do the conversion.
Old Nov 15, 2025 | 07:36 PM
  #35
wormy267's Avatar
wormy267
3rd Gear
Guys,
that’ll work
Old Nov 15, 2025 | 09:28 PM
  #36
chris1911's Avatar
chris1911
How long does it take to print each piece?
Old Nov 15, 2025 | 09:36 PM
  #37
hiltsy855's Avatar
hiltsy855
A couple hours to print.
To 3D Printed Cold Air Intake
Old May 13, 2026 | 07:15 AM
  #38
Acme54321's Avatar
Acme54321
1st Gear
Stumbled upon your thread and have nothing to do with Corvettes, but have some experience in 3d printing. You should heck out PPA-CF filament for this project. Prices have come down, Siraya Tech is about $60 a roll. It's super strong and the heat deflection temperature is around 200C/400F. As far as printability I find it about the same as ABS, maybe even a little easier.
I don't know the specs on your printer, but you'll need an enclosed printer with at least a 300C nozzle and 100C bed. You might be able to get away without an actively heated chamber though.
Old May 13, 2026 | 08:38 AM
  #39
LOST_C6_OC's Avatar
LOST_C6_OC
I would love the opportunity to print this out in PPA-CF but I don't have the file, unless someone was able to get it?
Old May 13, 2026 | 08:50 AM
  #40
smitty2919's Avatar
smitty2919
Any plans to dyno the new intake design over stock one?
