C7 fan running
Old Feb 16, 2024 | 05:37 PM
RJones#107's Avatar
RJones#107
1st Gear
Default C7 fan running
Fan constantly running & temperature gage not working. Any ideas on a fix?
Old Feb 16, 2024 | 05:58 PM
Moved to C7 Tech for some assistance.
Old Feb 16, 2024 | 07:39 PM
IA-SteveB's Avatar
IA-SteveB
This happened to me when I was installing a cold air kit. I had knocked the coolant temperature sensor connection.
Old Feb 17, 2024 | 07:52 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
You have a lazy thermostat. Rock Auto has OEM thermostats.. This also happened to me. Pretty easy change out. you won't lose to much fluid.
Old Feb 17, 2024 | 09:04 AM
Tinkertech's Avatar
Tinkertech
Thermostat or temp sensor.
Common problem.
Old Feb 28, 2024 | 02:52 PM
Red86Cfour's Avatar
Red86Cfour
definite lazy thermostat. The sensor is most likely fine. Change the tstat, and if the coolant is over five years, now is a good time to change it also. Disconnecting the negative battery terminal will reset the fault, such as it is. There will be no codes present.
Old Feb 28, 2024 | 09:35 PM
96GS#007's Avatar
96GS#007
Define "temp gauge not working". It literally doesn't budge off the 100* or whatever the low reading is or the temp never exceeds "xxx degrees" . If the former, check the sensor plug and test the sensor. If the latter, it's the thermostat.
Old Feb 29, 2024 | 09:16 AM
Red86Cfour's Avatar
Red86Cfour
A lazy or stuck open tstat problem will have as a symptom a zero reading on the digital performance screen, and the analog temp needle will stay at the lowest position. The fans will turn on full blast at shutdown, and at cold start.
Old Feb 29, 2024 | 09:30 AM
96GS#007's Avatar
96GS#007
The engine will still warm into the 150s (or more) depending on run time, outside temp, speed, etc. An open thermostat slows the rate.
You believe what you want and have him toss parts at it rather than performing some basic troubleshooting
Old Feb 29, 2024 | 02:39 PM
Red86Cfour's Avatar
Red86Cfour
Its true that the engine will still warm up based on load, outside temp, etc. I'm only advocating changing the tstat as thats been shown many times to be the culprit. It was in my case too. The sensor is easy to check with an ohm meter so no need to "toss parts" in place of troubleshooting.
To C7 fan running
