transmission issue
Old Feb 28, 2024 | 06:20 PM
p0p_sm0k3's Avatar
p0p_sm0k3
Cruising
Default transmission issue
I recently had a stage 3 monster installed. Had no issues till after a dyno tune. Sometimes shifting it feels like it catches something. Its not smooth. Then other times nothing. All smoth shifting. Sometimes when i try to throw it in reverse it catches or makes a slight grinding noise. One time it wouldnt even go into reverse it would just grind and wouldnt go. I had to restart it with the gear in reverse. Then no issues after that. Synchros?
Old Feb 28, 2024 | 09:40 PM
C5FORFUN2's Avatar
C5FORFUN2
Sounds like the clutch is not always disengaging properly. The reverse gear has no synchros.
Old Feb 28, 2024 | 09:44 PM
96GS#007's Avatar
96GS#007
Check the clutch fluid level. Flush using the "Ranger Method"....plenty of threads on that via search.
May also want to change the transmission lube. Manuals use ATF not gear oil. I prefer Redline D4 ATF but you'll get a million opinions on which is "best"
Old Feb 28, 2024 | 09:46 PM
30rpm's Avatar
30rpm
Agreed. Sounds like a clutch disengagement issue. May be due for a clutch bleed. How many miles break in on the clutch before the dyno session?
Old Feb 29, 2024 | 03:58 PM
p0p_sm0k3's Avatar
p0p_sm0k3
Cruising
Maybe 350-400 miles on it before dyno. I just bought new brake, tranny and diff oil. I hope that’s it. I was ripping on it today and fine.
To transmission issue
