LT4 exhaust Valves
Old Feb 23, 2024 | 01:16 AM
bc928's Avatar
bc928
Default LT4 exhaust Valves
The Lt4 exhaust valves seem to be nothing special. Stainless.
There are inconel and "Super allow" valves on the market in the same exact sizes.
One such "Inconel" exhaust valve is actually in the truck L8T engine. Same size as for the other Gen V engines (at least the Lt1 and Lt4).
Can't get them even though they are on all those trucks. Nice upgrade for the Lt4 exhaust. Backordered indefinitely like a few other items on the C7.
And they are half the cost of these:
https://www.jegs.com/i/Manley/660/12349-1/10002/-1
Also Ferrea, who I like as a company makes these: F2410P
https://gwatneyperformance.com/produ...valves-f2410p/
Actually Katech sells them as a performance option for the Gen V: https://katechengines.com/i-30497954...ust-valve.html
I bought the Ferrea as I wanted to know more about it. It is ~9x grams compared to ~7x grams on the stock LT4 exhaust. That is a pretty big difference. Tool steel retainers will be reducing the total mass in the valve train a bit, but those heavy exhaust valves... kinda concerning.
I would love to get one of the (cheaper) Inconel valves from the L8T on a scale to see if they are a compromise on weight. I may also buy one of the manley valves to see as the material manley uses is supposed to be different from the dense superalloy of the Ferreas.
Old Feb 23, 2024 | 10:19 AM
CPB's Avatar
CPB
Is there a specific cam or maybe RPM increase you are looking to achieve?
Old Feb 23, 2024 | 10:21 AM
bc928's Avatar
bc928
I am am building a 427 with a 2650 and have a BTR 4" stroke PD cam. RPMs will not be high but will be a track work car and DD.
The heavier valve is probably fine but man are they heavy.
Old Feb 23, 2024 | 10:24 AM
Katech_Mike's Avatar
Katech_Mike
Premium Supporting Vendor
The L8T inconel valve is 15g heavier than an OEM LT4 exhaust valve. They're great valves but as you've said they're unobtanium right now.
Old Feb 23, 2024 | 10:30 AM
CPB's Avatar
CPB
Pairing with their dual spring setup?
Old Feb 23, 2024 | 10:33 AM
bc928's Avatar
bc928
PSI 1516ML is the plan. They are beehive.
Old Feb 23, 2024 | 10:37 AM
Dano523's Avatar
Dano523
Lost, since you can throw more pressure at the Lt-4 or even ls9 to make more power than the 427, since the 427 has the cylinders too thin between each other, to throw real pressure at them. Also, with lsx blocks/heads with extra head bolts, holds even more pressure instead.
LS7 block and you can see how thin the cylinder sleeves are between each other, and why you can't throw major power at it.
As for DI, verse intake port injection, would favor intake injecting any day of the week if your going to run any PCV system on the engine, that is going to be dumping oil back into the intake manifold. With port injection, fuel down the intake manifolds does keep the intake valves clean, over the DI problem of no fuel down the runners to clean off the oil that the PCV is pushing down the same intakes.
Also at add, varable cams is only for Na motors to help them breath better, and goes out when the window when the motor is being forced feed breath'd by the blower instead.
So with 2650, you have the boost to make 1KHP, and now just need to build the motor that can hold that much pressure to make that kind of power.
bc928's Avatar
bc928
Ah so a bit lighter than the Ferrea. And cheaper! But simply don't exist in the GM network.
Old Feb 23, 2024 | 10:43 AM
bc928's Avatar
bc928
Hate to be a dick but I am one so....
Yes, you are lost. Or your over ten year old account was taken over by a random bot. This thread is about valves. Why the cookie cutter post?
Old Feb 23, 2024 | 05:51 PM
bc928's Avatar
bc928
I wonder why? Maybe everyone bought them knowing it's an upgrade of sorts.
Old Feb 24, 2024 | 12:39 PM
Dano523's Avatar
Dano523
Has to do with valve float on the super charged motor, and why the LT4 exhaust valves are lighter than the LT1's
https://www.onallcylinders.com/2019/...do-you-fix-it/
Also to point out, the way that GM tunes the motors, on the NA motors, they will go flat before redline in HP, while on the motors that are supercharged being forced feed, do not and you bang off the rev limiter still climbing hard in HP instead.
Old Feb 24, 2024 | 12:53 PM
bc928's Avatar
bc928
Wrong. LT1 and LT4 exhaust valves are same part number.
Old Feb 25, 2024 | 06:58 PM
Katech_Mike
The part number changed which means there was either a revision or the supplier changed. We have not seen any stock of the updated part number yet.
Old Feb 25, 2024 | 07:02 PM
bc928's Avatar
bc928
Thanks. It is not
12671857?
Old Mar 27, 2024 | 11:32 PM
bc928's Avatar
bc928
I wanted to update here. The inconel part number for the L8T that has been floating around and I posted here seems to have been swapped in a cost saving or possible convergence with -
"Yes, The 12671857 was removed and replaced by the 12733470"
Old May 1, 2024 | 01:05 AM
bc928's Avatar
bc928
Still waiting for the second part number replacement noted above. Ferrea valves VERY heavy. (Bought one)
Old May 1, 2024 | 09:51 AM
Katech_Mike
You're going to be disappointed.
To LT4 exhaust Valves
Old May 1, 2024 | 10:32 AM
bc928's Avatar
bc928
Ha, it will be okay. I'll check out the Manley as well while I'm waiting. I'm used to 40 year old Porsche part availability.
I was hoping the part supercession to the LS valve was good news.
Old May 1, 2024 | 10:35 AM
Katech_Mike
I'm only referencing the weight.
OEM LT1/LT4 - 74g
OEM L8T Inconel - 96g
Ferrea Super Alloy - 95g
Old May 1, 2024 | 10:37 AM
bc928's Avatar
bc928
OEM LT1/LT4 - 74g
Oh! Thanks for clarifying. I see...
