DEXRON Vl
Old Mar 13, 2024 | 07:58 PM
BluRace's Avatar
BluRace
Default DEXRON Vl
i am about to change transmission fluid in my 2014 M7.
i am having a hard time finding Dexron lll to purchase.
i have found several articles online stating that Dexron lll was phased out by GM in 2011 and replaced with Dexron Vl.
Does anyone have any experience with Dexron Vl in their M7 vehicle?
thx
Old Mar 14, 2024 | 12:06 AM
RonC7's Avatar
RonC7
GM manual transmission fluid p/n 88861800 is still available as are some synthetics.
For more info see the following threads:
https://www.corvetteforum.com/forums...l#&gid=1&pid=2
https://www.corvetteforum.com/forums...d-service.html
Have fun!
Ron
Old Mar 14, 2024 | 09:14 AM
ersatz928's Avatar
ersatz928
DO NOT USE DEXRON VI in the C7 manual transmission, ONLY DEXRON 3 or equivalent.
Use:
Amazon.com: Mobil 1 Synthetic Automatic Transmission Formula (1 Qt) : Automotive
Red Line Synthetic Oil. D4 ATF (redlineoil.com)
OR GM 10-4033 88861800
Old Mar 14, 2024 | 09:40 AM
vortech347's Avatar
vortech347
Red Line D4 ATF did make a noticeable improvement in my M7 when I switched from factory fill. Mainly the 1-2 shift when cold.
Old Mar 14, 2024 | 05:21 PM
CraigStu's Avatar
CraigStu
ANother Redline supporter. Really helped my 1-2 cold shift. I wouldn't even consider anything else.
Old Mar 14, 2024 | 09:31 PM
GOLD72's Avatar
GOLD72
thx
Do not use DEXRON VI in an M6 or M7 car. It is too thin. There are plenty of DEXRON III equivalent tranny fluids out there including Redline D4, AMSOIL ATF, AMSOIL Torque Drive, etc.
Old Mar 15, 2024 | 05:44 PM
Bill Dearborn's Avatar
Bill Dearborn
The GM recommended lubricant is available on Amazon and works just fine in my M7. The page says they only have 6 quarts in stock.
https://www.amazon.com/Genuine-Fluid-88861800-Manual-Transmission/dp/B00BK7M1EK/ref=sr_1_1?crid=13KZSP0Q7KV3Q&dib=eyJ2IjoiMSJ9.iw3JEfF7PXDgMK0ValAcQZuWoRdcm92gdkJIHHIiLO8.ZHv4ipBeouGRHD-jQUxCAU1yXzZcpSMcgZiY09se5Qo&dib_tag=se&keywords=88861800&qid=1710538928&sprefix=88861800%2Caps%2C277&sr=8-1 https://www.amazon.com/Genuine-Fluid-88861800-Manual-Transmission/dp/B00BK7M1EK/ref=sr_1_1?crid=13KZSP0Q7KV3Q&dib=eyJ2IjoiMSJ9.iw3JEfF7PXDgMK0ValAcQZuWoRdcm92gdkJIHHIiLO8.ZHv4ipBeouGRHD-jQUxCAU1yXzZcpSMcgZiY09se5Qo&dib_tag=se&keywords=88861800&qid=1710538928&sprefix=88861800%2Caps%2C277&sr=8-1
If you don't have a pump to pump the lubricant out of the container purchase the correct pump from Amazon. The transmission and diff fluid containers have different size openings so two pumps are needed if you are changing both fluids.
Bill
Old Mar 17, 2024 | 05:20 PM
Avanti's Avatar
Avanti
You DON'T want the wrong lube! Years ago a friend put the wrong fluid (typical gear-lube) in a T-5 (requiring auto-tranny fluid). Not good!
Old Mar 19, 2024 | 02:03 PM
Blackwater0323's Avatar
Blackwater0323
Same here plus a MGW shifter made all the difference.
To DEXRON Vl
