Air filter question
Old Mar 28, 2024 | 11:16 PM
flynhi's Avatar
flynhi
Default Air filter question
I’ll be changing the air filter in my 17 ZO6 and have read somewhere that when I disconnect the MAF sensor it will cause a check engine light and throw a code UNLESS I disconnect the battery negative terminal first.
True or false?
thanks for your answers
will
Old Mar 28, 2024 | 11:26 PM
C5FORFUN2's Avatar
C5FORFUN2
False
Old Mar 29, 2024 | 01:38 AM
NortonCO's Avatar
NortonCO
Originally Posted by C5FORFUN2
False
I disconnected my MAF when installing a CAI and when cleaning its filter. I did NOT disconnect the battery either time and had no such issue.
Old Mar 29, 2024 | 08:13 AM
jaxcam02's Avatar
jaxcam02
If your worried about it you can remove the sensor from its housing while leaving the connector attached
Old Mar 29, 2024 | 10:01 AM
flynhi's Avatar
flynhi
Ok
thanks
Old Mar 29, 2024 | 12:34 PM
kodpkd's Avatar
kodpkd
Just don't turn on the ignition when it's unplugged. I did mine without any issue. I used the blue one.
Old Apr 6, 2024 | 08:06 PM
BluRace's Avatar
BluRace
i replaced mine with an Air Attack Blue (or whatever it is officially named) last week and have driven the car several times with no issues.
i did NOT disconnect the battery.
side note
what was interesting to me is the cabin air filter was 10x more filthy than the engine air filter.
To Air filter question
