Side mirror glass replacement
Old Apr 13, 2024 | 04:25 AM
Corvettemac's Avatar
Corvettemac
Default Side mirror glass replacement
Has anyone ever done just the side mirror glass replacement ( just the glass alone ) without removing the whole unit ?
does it snap in or etc .
i have auto dimming but probably replacing with standard regular miror ?
thanks in advance
Old Apr 13, 2024 | 11:38 AM
RonC7's Avatar
RonC7
Check this out, Heated and unheated available. Installation instructions are in the listings.
https://www.rockauto.com/en/catalog/...ror+glass,6484
Ron
Old Apr 14, 2024 | 06:42 AM
Do a search in this section on outside mirror glass replacement. Several hits will show up.
Old Apr 15, 2024 | 07:48 PM
BluRace's Avatar
BluRace
i replaced the LH mirror with a Panoramic version. Took my time to pop it out and the other one in, but it was easy.
Old Apr 1, 2025 | 11:27 AM
RRRoamer's Avatar
RRRoamer
3rd Gear
Mine (2024 Z51 2LT) is at the dealer right now for the driver side mirror. The auto dimming failed (locked in dim mode) back in May 2024. Part ordered Aug 2024. They FINALLY knew they had the part two weeks ago (after a ton of calls, they finally admitted they "had one in stock with a customers name on it". I said "yeah, probably MY NAME!" It was...) The one day to install/seal/test that was "planned" suddenly became two days when I dropped the car off yesterday. I just got off the phone with them and they the mirror assembly is installed, but they are fighting with the programming. Ever time they open the door, the mirror goes to the far up and out position and has to be readjusted.
Sigh.
Old Apr 3, 2025 | 12:08 PM
miami08VETTE's Avatar
miami08VETTE
There are several posts on the forum as how to set the mirrors. They are either too lazy or stupid or both to get it done. Barring an unknown issue that they may have caused? It's not rocket science! Good luck!
To Side mirror glass replacement
