Failed control sensor creates $9k in repairs?
Old Apr 29, 2024 | 10:47 PM
red-vette-ragtop's Avatar
red-vette-ragtop
Default Failed control sensor creates $9k in repairs?
2014 convertible, 116k miles
One day driving to work. Suddenly, engine/muffler pitch goes way low, becomes sluggish. OBD reading returns about 12 codes, among which are 3 codes saying 3 cylinders misfiring:
P0030 H02S Heater Control Circuit Bank 1 Sensor
P0031 H02S Heater Control Circuit Low Bank 1 Sensor 1
P0050 H02S Heater Control Circuit Bank 2 Sensor 1
P0051 H02S Heater Control Circuit Low Bank 2 Sensor 1
P0443 Evaporative Emission System Purge Control Valve Circuit
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P3403 Cylinder 1 Deactivation / Intake Valve Control Circuit Low
P3427 Cylinder 4 Deactivation / Intake Valve Control Circuit Low
P3443 Cylinder 6 Deactivation / Intake Valve Control Circuit Low
P3451 Cylinder 7 Deactivation / Intake Valve Control Circuit Low
Took it to the dealer I trust. They said they had to tear down the engine compartment to find out what was going on (timing belt? etc.) Got the call: they say it was a control sensor (solenoid?) that failed and took out the oil pump, which summarily took out the water pump due to the leaking oil and another or two sensors. They also told me that the torque tube needs replacing because of a failed bearing. "That one sensor failure took all of that out?!!!" "Yes."
I replaced the torque tube a year ago before I took delivery of the car. I have an OBD mod installed to prevent it from going into the infamous AFM mode.
9K in repairs. Ouch. Does any of this sound right to you? I do trust this dealership, I've been doing business with them for a long time. They don't give me any stories and have found ways to save me money when they can. I know these Vettes are complex sports cars. But one sensor can do this? What's your take?
Last edited by red-vette-ragtop; Apr 29, 2024 at 10:51 PM. Reason: Incorrect part name
Old Apr 30, 2024 | 12:42 AM
96GS#007's Avatar
96GS#007
Sounds like bullshit to me
The oil pump is not going to take out the water pump. They are physically separated and the only way an oil pump would do that is if it led to a huge gaping hole in the block where all the internal parts exited the engine.
There's only about 100 sensors on this engine that all control something so "control sensor" is the equivalent of saying "something broke". Need to know explicitly what sensor(s).
There is no timing belt. These cars have a timing chain.
Based on the codes it sounds like the DOD/AFM system has failed. There are a variety of sensors that control that although more often than not, one of the lifters wipes a cam lobe.
As for the torque tube....If it was installed less than a year ago, it should be under warranty. Check your paperwork. Don't know how they would have tested the torque tube unless they have the engine out or drove the car.
This is all just speculation since most of your description of what they did, frankly, doesn't make sense.
Old Apr 30, 2024 | 08:34 AM
Tinkertech's Avatar
Tinkertech
From your description it sounds like you had a Intake Valve Control Circuit sensor failure that shut down the AFM system. ( i read that you disabled the AFM thru the OBD port ).
All the rest of the issues they 'found' depends on how the car was taken care of.
But I have a very hard time believing that all these failures are caused by any sensor.
I believe the tech just started taking the car apart and once in pieces just to fire the parts cannon at it.
I bet if this car was under warranty GM would not allow or cover this repair sequence.
But if its just a single sensor, well this dealer has a boat payment due.
Good luck.
Old Apr 30, 2024 | 09:22 AM
LT1GMC's Avatar
LT1GMC
I wouldn't trust that dealer any longer, that is the worst diagnosis I've ever heard. They have no idea what really happened, and I would not trust for them to repair it properly if that is their level of capability.
Old Apr 30, 2024 | 11:38 AM
Flattman's Avatar
Flattman
One sensor would not take out all of those parts - ever and your "trusted" dealer should not be. For them to say one sensor took out all those parts is a huge red flag and to suggest an engine sensor took out a torque tube bearing is absurd.
Old Apr 30, 2024 | 11:54 AM
kodpkd's Avatar
kodpkd
You got screwed!
Old Apr 30, 2024 | 12:26 PM
AnotherNorskie's Avatar
AnotherNorskie
Maybe the dealer has a pending boat payment?
Old Apr 30, 2024 | 12:35 PM
shekmark427's Avatar
shekmark427
OP, does this dealer have a actual Corvette certified tech ( is that what you call them? I'm new to this). Just wondering. Good luck.
Old Apr 30, 2024 | 02:14 PM
14point5's Avatar
14point5
Cruiser
Veteran: Marine Corps
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
Haven't I read here that incorrectly replaced torque tubes can put pressure on the crank thrust bearing which puts ground bearing metal into oil circulation and then causes lifter or rod bearing failures in about 3000 miles?
How many miles ago was the torque tube replacement?
Old May 3, 2024 | 11:01 AM
Tinkertech's Avatar
Tinkertech
After reading your post a couple of times I get the sneaking feeling that when they replaced the torque tube that they did not set the clearance correctly, thus the trashed engine.
The time period seems about right for the thrust bearing to be destroyed taking the engine with it.
Good luck in your repair and keep us informed as to what was done.
Old May 3, 2024 | 11:47 AM
spoolin98's Avatar
spoolin98
Your first mistake is trusting any dealer. Many vendors aren't much better so do your research before letting someone work on your car.
Old May 10, 2024 | 07:16 AM
What they are suggesting does seem suspect. Good luck getting this straightened out and hope it does not get messy, especially if the torque tube install led to all this.
Old May 13, 2024 | 12:10 PM
CraigStu's Avatar
CraigStu
If the engine isn't running properly how did the diag a TQ tube problem?
To Failed control sensor creates $9k in repairs?
