AFM RANGE Question
Old May 2, 2024 | 08:45 PM
flynhi's Avatar
flynhi
Default AFM RANGE Question
I tecently began using a Range plug in to defeat the AFM Iin my 17 ZO6
shotly thrreafter I began to see a BRAKE WEAR message
i inspected the pads and they all seem to have plenty of wear left.
is anyone else having this issue?
If I unplug the Range and still have the message, will the OBD show which wheel is sending the message?
Thanks for you help
Old May 2, 2024 | 08:51 PM
aklim's Avatar
aklim
I don't know what the AFM has to do with brakes but why not unplug it and see?
Old May 2, 2024 | 09:31 PM
flynhi's Avatar
flynhi
I plan to
Old May 3, 2024 | 03:04 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
I've never seen or heard of this reported with the Range device, on Corvette or any application honestly.
Let us know what you find.
Old May 10, 2024 | 07:08 AM
I have run the Range AFM Eliminator for a number of years and have never encountered such a message on the car. I suggest that it is something else causing the warning message to occur.
Old May 17, 2024 | 07:35 PM
ball-z's Avatar
ball-z
i see that there is 3 different color range units are they all the same doing the same job or are they different
Old May 17, 2024 | 08:03 PM
aklim's Avatar
aklim
Same job, different bling AFAIK.
Old May 17, 2024 | 08:06 PM
Mike@DiabloSport
Supporting Vendor
all the same, simply aesthetics
Old May 21, 2024 | 01:55 PM
kodpkd's Avatar
kodpkd
When you checked the break pads,,,,, did you look at the inside pads. They wear faster and are overlooked sometimes.
Old May 27, 2024 | 11:00 PM
TxLefty's Avatar
TxLefty
I know that the CCBs have a wire in pads that will sometimes break and give a false warning regarding pad wear. Do the standard (non-CCB) pads have the same system?
To AFM RANGE Question
