C7 Diff Carrier/Trans Assembly VS C5 Mounting Compatability
Old May 3, 2024 | 06:05 PM
Hary Gahtoe's Avatar
Hary Gahtoe
Default C7 Diff Carrier/Trans Assembly VS C5 Mounting Compatability
Hey, looking for technical fitment background, to swap C7 A8 rear suspension/diff to C5 chassis. Searches show nothing
Thanks for replies
Hary
Old May 6, 2024 | 09:26 PM
Avanti's Avatar
Avanti
There is a reason you are finding nothing; the C7 was a fresh design from scratch. Maybe with C5s and C6s.
Old May 11, 2024 | 09:53 AM
LT1GMC's Avatar
LT1GMC
I believe the C6 body configuration is different above the rear axle due to changes in the differential and the differentials will not fit the C5. C7 is totally different so thats a no go for sure.
Old May 11, 2024 | 10:31 AM
96GS#007's Avatar
96GS#007
If you're trying to install a diff from a Z51/GS/Z06 car with the eLSD you'll also need all the electronics and the pump.
Zero gain that I can think of for putting a C7 diff in an earlier car.
To C7 Diff Carrier/Trans Assembly VS C5 Mounting Compatability
