Flex fuel corvette
Old May 7, 2024 | 04:47 AM
Numis33's Avatar
Numis33
Default Flex fuel corvette
About a 2 years ago I was at my tuners shop in Sebastian Florida and a long time customer told me he had a Camaro he ran on e85. He said both his Camaro and my c7 were capable of running e85 .All the tuner had to do is enable the flex fuel map on the cars computer. Does anyone know if this is true? And if it is why are people installing alky kits.
Old May 7, 2024 | 09:52 AM
14point5's Avatar
14point5
Cruiser
Veteran: Marine Corps
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
Flex Fuel Sensor Install
How To: Flex Fuel E85
Old May 7, 2024 | 10:16 AM
vortech347's Avatar
vortech347
He's kind of right. As 14point5 added, you have to install a flex fuel sensor and then have the car tuned. The tuner will tune your car to pump gas and then do a second tune on E85 and the computer will then do it's own corrections based on the E% you run.
If you are not doing any other mods it's fairly expensive to gain ~20-25hp on a NA car. I did it along with mods because the car was already half apart so it only added about $500 to a 12k price tag. I gained 23hp and 23 ft lbs of torque on E vs 93 post mods.
ZO6LIFE's Avatar
ZO6LIFE
I run E85 on my 2013 SS. I get another 60rwhp with it. Note: there are other mods, not a stock engine.
SBE, stock heads, stock intake manifold.
Old May 7, 2024 | 10:19 AM
vortech347's Avatar
vortech347
I assume you are forced induction?
Old May 7, 2024 | 10:30 AM
ZO6LIFE's Avatar
ZO6LIFE
Correct, ECS Novi 1500. Also cammed.
Old May 7, 2024 | 10:42 AM
vortech347's Avatar
vortech347
Makes sense. What fueling mods did you do? I have been looking at it and it will take a lowside pump, LT4 HPFP and LT4 injectors.
Old May 7, 2024 | 10:52 AM
ZO6LIFE's Avatar
ZO6LIFE
I did a ZL1 pump with DSX aux pump. Put in FIC 1000 injectors. Did 2 tunes . One on 93 and one on E85.
Old May 8, 2024 | 07:22 PM
Chazzmania's Avatar
Chazzmania
Just added Flex Fuel sensor to my build which was a major overhaul. I also added a P3 gauge to monitor my E content during fill ups.
Old May 9, 2024 | 07:55 AM
Internets_Ninja's Avatar
Internets_Ninja
Flex Fuel is easy. If you're an LT1 you can run full pump E with a flex fuel sensor and a tune. If you're an LT4, the stock fuel system won't allow you to run full pump E, you'll need to mix down to what your fuel system can handle which will depend on your mods. I tune these all day long. Easy way to pick up power. The LT4's benefit the most from E50+ but the LT1's still pick up a solid 20-25 rwhp in stock form.
To Flex fuel corvette
