Torque tube removal, rebuild, and re-install procedure
All,
I have a 2014 Z51 with automatic transmission, and I need to rebuild the torque tube.
I have been searching for the GM procedure, but have come up empty.
A few post lead to databases, but when i get there, i don't have access. I have tried to get access, without success.
Can some on please point my in the direction of the procedure, or procedures, required to do the removal and re-install? I want to ensure i know all the torque specs, and special set up data, like prop shaft as an example.
Thank you in advance,
dmatzinger (05-16-2024)
There are so many that have not followed the procedure and have wiped out the thrust bearing!!!! And it happens fast so make sure it's done exactly as described
Dave
