C-7 locks in overdrive
Old May 26, 2024 | 08:36 PM
WVFD1017's Avatar
WVFD1017
Cruising
Default C-7 locks in overdrive
I have a 2014 Stingray convertible with 10,000 miles. For the first time last week, the transmission locked in overdrive when I punched it in the sport mode. When I punched it into overdrive up to about 50, I let off the gas. It didn’t disengage until I got down to about 30. I tested it and it did it several times. Again, it was in the sport mode. I did the same thing in touring mode, and the transmission disengaged immediately. It was fine in touring mode, but not in sport mode. Any thoughts on this issue. Thanks.
Old May 27, 2024 | 06:32 AM
14point5's Avatar
14point5
Cruiser
Veteran: Marine Corps
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
I'm not sure I agree with the terms your are using but it sounds like you are describing the "Performance Shift" feature of the C7 Corvette Automatic 8 speed transmission.
Performance Shift Active thread
Old May 27, 2024 | 07:46 AM
Sure sounds like performance shift mode to me too. My A6 does this with a blip of the throttle.@
Old May 27, 2024 | 09:40 AM
kodpkd's Avatar
kodpkd
What is overdrive?
Old May 27, 2024 | 09:46 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Out of my 2014 Owner's Manual 9-41
Track – Performance Algorithm
Shift (PAS) recognizes
aggressive cornering, heavy
braking, and high acceleration to
select and hold lower gears
when not using paddles.
If the car thinks you are driving aggressive, it holds the revs up and keeps the car in lower gears to enhance performance. I call it the puppy mode.
Elmer
Old May 27, 2024 | 05:21 PM
WVFD1017's Avatar
WVFD1017
Cruising
Thanks guys for the replies. After reading the performance shift mode thread I agree. I really appreciate your feedback.
To C-7 locks in overdrive
