High HP suspension
I am in the middle of my engine build and wanted to see what everyone has done regarding the suspension on their high HP C7's. My car is a base Stingray without the mag ride or Z51 package. I am basically a clean slate to start from. I thought about going the coil over route or should I just install better shocks? I am going to be somewhere between 850 to 950 rwhp with a manual. I know suspension will pay a part in the way the car reacts to the HP. Any input would be appreciated. Thanks
All the best, in any event.
For "some spirited street driving and occasional drag" the stock suspension may suit you just fine to start out with, and provide a balance of nice ride all around and high performance when needed. I'd suggest for your needs to wait until you find issues with your suspension/traction to refine vs buying parts prior to your initial testing.
The tires would likely need upgrading firstly just to hookup all that power as I am sure you know. Then you can go into fine tuning the ride if you want to chase more and more speed at launch (or in the curves?) and if you find your suspension as a limiting factor. Keep in mind the more you setup for drag however, the less it will handle your "spirited" duties or normal driving. If you need balance for various driving needs and arent trying to win trophies on the weekends, the factory setup is kind of hard to beat.
No matter what you do, with all that power you will likely need restraint with your right foot more than adding parts that will "handle" that power for you...!!
Have fun and stay safe out there
Penske are the defacto shock you can buy and have it handle whatever you need. They can also custom valve them for your application.
