Looking INFORMATION on Tuning
So here's my question ... is there any such thing as aftermarket control modules when tuning a C7 Corvette (Z06)? Second question who are the reputable aftermarket tuning shop you all would recommend?
Thank you
Brian
Thank you
Brian
How much mods do you plan to do? Simple couple of things, DIABLEW. If it is radical stuff, I would prefer to get it on a dyno. Nothing against DIABLEW but that is my personal preference.
Other things someone may have installed would be a "Range Device" and/or a Throttle Controller. Those are piggyback items. Just unplug and remove them as desired.
If it's a full up race car, then you get into things like aftermarket ABS, MOTEC controllers, etc
As far as pulling the transmission.....$$$. The rear cradle needs to be dropped and it needs to be separated from the diff since it's a trans-axle arrangement. Then you have the actual cost of repair. At best they might give you a price range but there's no way to give a definitive number without knowing what (in theory) is broke. Figure $2k-$3k for remove/replace and then $x for the actual rebuild.
The stock A8 is a strong transmission and is behind some cars making 900 HP , it takes a lot to destroy an A8
See my post #4 ... about a Garage Relearn
A8 REBUILD QUESTION about PROGRAMMING - CorvetteForum - Chevrolet Corvette Forum Discussion
Dave
Dave
Side question. My TCM was flashed with the appropriate program then it was altered for a better shift. Supposedly it was an update for the 2016 MY. We downloaded the program and the tuner did something. Suggestions?
he is a friend of mine and also tuned my C6 and C7 until I put the blower onThe Garage relearn has nothing to do with the " TUNE" ........
The procedure 1st puts the transmission in learning mode and will cycle all shift servos to learn what pressure/volume is needed and what is the release time for each clutch pack. The trans has to be up to temp before the process will start and foot needs to be held firmly on the brake pedal
It's imperative u do not try to end the process before it completes or try to drive the car, you could BRICK the TCM and leave your car stuck in Neutral.
The trans will make some pretty crazy noises that might scare some during this part of the test but it's all normal
After completing the 1st part which takes about 35 minutes, the Software with tell you the relearn is complete and the TCM is now in a learning mode, you now can shut the car off wait for about 10 minutes and then restart the car, this will allow you to drive car after the relearn,
For about the next 100 to 200 miles, The TCM is measuring the input shaft speed and output shaft speed during each gear change as it searches for the correct pressure to apply, and the correct release time for each clutch pack to make a perfect shift at every speed and condition it faces. this includes measuring engagement time when you first drop it into gear, if the TCM detects a harsh shift or engagement, it will make a correction for next time
It is very important during this " learning" time to vary your driving style!! You need to drive it like your fathers Buick at times but more importantly you need to drive it like you stole it and all points in between otherwise you might still experience poor shift quality.
During this time, you might experience a poor shift, harsh engagement, harsh down or upshifts, shift flair between gears, don't worry as all off this is normal and part of the relearn process
Any competent transmission shop that has diagnostic equipment (GDS2 is one, plus you need a GM MDI communications device) that is needed and knows how to do this process, if they don't know what you are talking about ... RUN , do not walk away as I would not let them work on my car
Dave
Brian
Brian
Diablew had me do a backup and he recoded it to the new TCM & ECM. Installed the new programs and it seems to be fine. So the question is this, IN YOUR OPINION:
1. Is that the best program possible that would prevent the damage of the transmission or should I try find a better solution
2. With the new program from Diablew, do you think it would incorporate any changes from the GM TCM update?
TIA
TIA
Doing an update, is like updating computer BIOS , u just don't do it unless there is a need . You know how many updates there are for the TV that you watch....no because if it works you are fine with it right? Just look at all the C8's that are having issues with over the air forced updating, sounds like a good idea but in reality it's not .
2- Updating modules just because does not extend the life or prevent damage, unless it's a pretty serious update
If that's the case , there would be a TSB or a recall issued
2- With GM module updates, anytime you get a module updated it will overwrite any old settings etc , so any changes that Lou made to the original TCM or ECM program would be replaced by the update . If you had sent Lou a new copy of your tune and TCM file after you had the updates done and he updated them , then you answer is yes it would incorporate any changes that GM made plus changes that Lou made. If he just had you restore you orginal backed up modified files then chances are , the old files overwrote the new GM file
But if there was nothing wrong with you car in the first place .... then you have nothing to worry about using the old file........
Remember, the Garage Relearn is NOT module update , it's a "reset" of the factory settings and a process that puts the trans in Relearn mode
Dave
Brian
A normal C7 does not have aftermarket modules , it might have a modified tune for more power and if that's the case , if it's a GM dealer they can read what's called the "CVN" file and tell you if it's been tuned ( there is only one device that can modify a tune and not be detected but the chances are small that they used that device )
Only a highly modified C7 would have a aftermarket ECM , these units are usually reserved for full race vehicles or a serous street car do you would know instantly that it had an aftermarket ECM
If you are unsure, walk away , there are plenty of low milage c7's for sale everywhere ......
Dave
I can personally verify this fact .......
Dave
The only reason I went to the local GM dealer was to get an estimate on repairs, if in fact it needed transmission R&R so I can make an informed purchasing decision. I highly doubt the car has anything other than tuned OEM modules based on all of your responses which I VERY MUCH appreciate.
The car is still available, but I am continuing to look for other Z06's, this just happens to potentially be a good deal and exactly what I'm looking for.
Thanks Again!!
Brian
Thanks Again!!
Brian
