Error message…must roll down window
Old Jul 8, 2024 | 05:03 PM
Teena Jefferson's Avatar
Teena Jefferson
4th Gear
Default Error message…must roll down window
My 2016 Stingray has been not starting sporadically showing an error message “open and close drivers side window” then the same message with passenger side window. Check engine light comes on. After windows are opened and closed, engine will start. My dealer thinks I’m crazy. No codes are showing up. Has anyone had this happen and what was the reason and how to fix it?
Old Jul 8, 2024 | 05:37 PM
Thomasmoto's Avatar
Thomasmoto
Default Error
When you say " it won't start " will it turn over?
Old Jul 8, 2024 | 05:44 PM
Teena Jefferson
4th Gear
it barely turns over, like the battery dies, then after I roll down the windows and roll them back up again, it will start up just fine. Also during this process my check engine light appears, then after I start it disappears again.
Old Jul 8, 2024 | 05:53 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you had the MIL illuminated it should have stored a trouble code and would be history if not a current code ...if your scan tool has Global OBD2 I'd look in there for a trouble code.
Old Jul 8, 2024 | 05:54 PM
Thomasmoto's Avatar
Thomasmoto
Default Z06
How old is the battery? They can cause lots of different elec problems when they go bad. Check it before and after you get it to run. What is the voltage at the battery. Does it change?
Old Jul 8, 2024 | 06:49 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
When it says roll the window down, you do BOTH windows. Roll it down, roll it up AND HOLD IT UP for 5 seconds. Do that to both windows.
Also, sounds like your battery might not be up to snuff.
Elmer
Old Jul 8, 2024 | 07:01 PM
Teena Jefferson
4th Gear
My battery is only a year old. Dealer said voltage is good. Battery is good. I’ll try the window suggestion and see what happens. Thank you
Old Jul 8, 2024 | 08:33 PM
RonC7's Avatar
RonC7
So your car is losing window indexing. Are you losing any other settings such as radio presets or seat memory? A bad battery is known to cause odd electrical glitches.
Charge the battery and see if the problem persists. A battery can go bad at any time. It needs to be tested under load, just reading the voltage is not good enough.
Ron
Old Jul 8, 2024 | 09:27 PM
Teena Jefferson
4th Gear
Ron
Yes, radio presets, time and console settings need to be reset. Battery was charged today at the dealer so if it happens again I guess we’ll replace it again. . Thank you
Old Jul 8, 2024 | 10:31 PM
RonC7's Avatar
RonC7
A 1 year old battery should be full replacement warranty or at least prorated. Have them load test the new battery before installing it. I have seen bad batteries on the shelf.
GL
Ron
Old Jul 9, 2024 | 07:38 AM
Texan79423's Avatar
Texan79423
Holy water... Sprinkle holy water over the roof and say three hail Mary's is the only cure.
Old Jul 9, 2024 | 09:31 AM
kodpkd's Avatar
kodpkd
Did you try tightening the battery connections?
Old Jul 15, 2024 | 09:36 AM
Does sound like a battery problem. Hopefully a new one would get the car working properly again.
To Error message…must roll down window
