Triple flush
Old Jul 10, 2024 | 08:49 AM
Stephensmatlak's Avatar
Stephensmatlak
1st Gear
Default Triple flush
Good morning, I just purchased a 2014 c7 with 43000 miles, should I get the triple flush cause I do feel a Lil shudder. Also how do I get the 4 to 8 Cylinder delete.
Old Jul 10, 2024 | 08:59 AM
Tinkertech's Avatar
Tinkertech
Yes, get the triple flush.
Eliminate the V4 mode by using the Range device or tune it out by using the Diablo I3 tuner.
I tried both and ended up with the Diablo I3.
Old Jul 10, 2024 | 10:31 AM
Dreamer2's Avatar
Dreamer2
2014 has the 6 and not the 8spd. 6spd does not share the incorrect trans fluid issue the 8 has.
Old Jul 10, 2024 | 10:24 PM
Dcasole's Avatar
Dcasole
why would you triple flush an A6 ?.
Dave
Old Jul 10, 2024 | 10:29 PM
Dcasole's Avatar
Dcasole
OP if you are feeling a little "shudder" its the transition to V4 mode and back to V8 .... The A6 was not affected by the same "shudder" the A8 had , believe me you would know , it feels like u are on rumble strips .... , cheapest way to stop AFM , buy a range, mid price option, get a Diablo, semi expensive, have it tuned out with HP Tuners by a tuner. Expensive , swap out cam for a non DOD cam
Dave
Old Jul 10, 2024 | 10:43 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
A6, not the A8. The A8 needed the triple flush. If you have a shudder, the triple flush will not correct your problem.
Elmer
Old Jul 11, 2024 | 09:00 AM
Tinkertech's Avatar
Tinkertech
Dave
Sorry, read the post too fast and missed the A6 part.
Next time i'll pay more attention.
Old Jul 11, 2024 | 09:31 AM
kodpkd's Avatar
kodpkd
I have the 2014 A6. I purchased it with about 35,000 miles. I ended up changing all the fluids on the car, not really that hard to do. I wanted to be sure someone didn't put some kind of crazy snake oil in the car. You never now. Do some research and update your car with the correct GM recommended fluids. The rear end is easy, some of the cars don't have enough oil in the rear end from the factory.
Old Jul 12, 2024 | 09:11 AM
Tinkertech's Avatar
Tinkertech
Curious, what ATF is GM using on the A6 trans today?
Did Gm just change to the Mobil 1 Blue label for all trans, A6 and A8?
Inquiring minds want to know.
Old Jul 15, 2024 | 09:13 AM
For the 4 to 8 cylinder transition, just buy a Range AFM Eliminator and plug it into the OBD port. Works great.
Old Jul 24, 2024 | 01:48 PM
Andydp's Avatar
Andydp
How about a positive experience regarding the triple flush ?
Triple flush done last week. I noticed a difference even when I was coming out of the dealer lot. My wife drove the car and she commented on how much smoother the transmission is shifting.
Some answers: I went to a local dealer because this one has three Corvette mechanics on staff. (Mohawk Chevrolet, Ballston Spa, NY)
Cost was about $1,100. I had them do an oil change while it was up on the lift. Doing the Corvette Caravan next month so I figured the oil will be close to needing a change when we get back.
Old Jul 25, 2024 | 06:55 PM
LT1GMC's Avatar
LT1GMC
Dave
So I have to ask: Why do people state you have to swap out the cam for a DOD delete? If you do the other parts, replace the DOD lifters with standard, block the oil ports and do the tune, the engine is the same as it was in V8 mode previously. Now I see if you want a bigger cam, but if not I don't why the requirement to replace it.
Old Jul 25, 2024 | 07:47 PM
Dcasole's Avatar
Dcasole
The cam profile for Dod lifters is different than a non DOD profile
You cant just replace the lifters
Dave
Old Jul 26, 2024 | 08:34 AM
Tinkertech's Avatar
Tinkertech
Dave
BINGO!
To Triple flush
By Michael S. Palmer | 2026-06-03 09:39:05
