Does a LT4 fuel pump work with LT1 fuel rails in a LT1 engine? Upgrading for A&A supercharger addition and adding LT4 pump and injectors. I know the LT4 has different fuel rail but its for LT4 supercharger clearance. Not sure if any other reason.
Thanks!
Thanks!
GM advises against reusing the small metal fuel lines. They have crush fittings and unless you really wrench down on them there is a risk of leaking.
They do not have crush fittings, I have reused my fuel lines many times over now. They are a ball and seat design.
OP yes, you need to order the LT4 HPFP, the LT4 low pressure fuel line without the restriction orifice in it, you also need both of the LT4 hard fuel lines. The LT4 fuel lines have a much softer bend in the corners than the LT1 lines in order to maximize fuel flow to the injectors.
