P3 Question
Old Aug 22, 2024 | 10:13 AM
LT1GMC's Avatar
LT1GMC
Default P3 Question
Will a C7 Stingray with added 7 psi boost supercharger read boost on a P3 from the ECM with the standard map sensor or does it require an added external boost sensor?
Thanks, installing a P3 and want to wire anything extra at the same time.
Old Aug 22, 2024 | 01:04 PM
7LitreC5's Avatar
7LitreC5
It sure should. My 19 Z06 does. I did have to add their gadget to read ethanol % though.
Old Aug 23, 2024 | 08:28 AM
LT1GMC's Avatar
LT1GMC
You had to add an additional sensor for the E85 when you already had an E85 kit on the car?
Old Aug 23, 2024 | 10:47 AM
7LitreC5's Avatar
7LitreC5
When I bought my P3 3 or 4 years ago, yes that was the case. I had to buy their circuit that converts the frequency that comes off of the fuel composition sensor to a voltage.
I just looked at the P3 web site and it looks like the gauge may now read the ethanol % off of the OBD port but I'd verify that.
In any case, I really like the gauge and it worked flawlessly since I installed it.
Old Aug 23, 2024 | 05:24 PM
9sec's Avatar
9sec
I had the old style p3 sent it back and they added the new software so I don t have to use the old ad on anymore
Old Aug 23, 2024 | 07:37 PM
7LitreC5's Avatar
7LitreC5
Thanks. I'll look into doing that.
Old Aug 26, 2024 | 05:09 AM
Lux's Avatar
Lux
LT1 only has a 1 bar map sensor so will not read positive manifold pressure. OP will need to upgrade to a 3 bar map sensor and get a baro breakout harness so the ecu doesn't read boost as elevated atmospheric air pressure.
https://dsxtuning.com/collections/br...nt=30058995723
To P3 Question
