Check Engine Light - Please Help
Old Aug 25, 2024 | 05:57 PM
Chevyguy1980's Avatar
Chevyguy1980
5th Gear
Default Check Engine Light - Please Help
Hello everyone, thanks for allowing me to join your site. I'll get straight to my issue.
I have a 2016 Stingray. The car sat in my garage for 12 months with a trickle charger. I recently took it to get smogGed, at which point it did not pass. Technicians told me to drive the car 100 miles and bring it back. 5 minutes after leaving the smog station, the CEL came on. I connected an OBD scanner to the car and the following 2 codes came up, P26C8 and P0711. After some research, I figured it was either the TFT Sensor, Wiring Harness, or a confused computer that was still hibernating from a very long winters nap. I decided to drive the car around for about 30 minutes at varying speeds/conditions. I hooked the scanner up again, but this time the codes were P26C8 and P12FD (Exhaust Flow Valve Stuck Open Bank 2). But why am I getting different codes?? And now the P0711 isn't coming up. What might be causing this? Should I continue to drive the car more so the computer can finish doing everything it needs to do? PLEASE HELP!! THANK YOU
Old Aug 25, 2024 | 06:11 PM
Moved to C7 Tech/Performance.
Old Aug 25, 2024 | 08:50 PM
kkupec02's Avatar
kkupec02
Welcome
Old Aug 25, 2024 | 11:45 PM
aklim's Avatar
aklim
Cars don't hibernate, nap or get confused. Why did smogGED say it didn't pass? If you just hooked up the battery and drove it there, maybe it didn't go through the readiness monitor checking which is has to do when you disconnect the battery. Speaking of which, how old is the battery? Have you had it load tested? Since it is charged up, it should not have that readiness monitor issue so maybe the battery is going south?
Old Aug 25, 2024 | 11:59 PM
Chevyguy1980
5th Gear
Hi aklim, the car did not pass smog due to the OBD II. I mentioned the car had been sitting for a year so the techs told me to drive it 100 miles and bring it back. I never disconnected the battery. I had purchased a new battery a month before it sat for the year, but I kept that battery on the charger the entire time. The day I took it to get smogged, I put fresh gas in it, then drove straight to the smog station. I realize I should have driven the car much more before doing that. The battery has been fine since taking it off the charger on 8/24 in the morning. But maybe the computer needs to go through a checklist of things first, which can only happen after the vehicle has been driven more? I don't know. Thanks for the reply
Old Aug 26, 2024 | 04:56 AM
Lux's Avatar
Lux
The ecu takes a certain amount of drive cycles before all the obd2 monitors read as ready. Drive the car 50 miles somewhere. Shut it off. Restart it and then drive back and you should be ready for a obd2 scan. Clear the codes before you go and see if any come back after. Just dont clear them after the drive otherwise you'll need to do a couple more drive cycles to get them back to ready.
Old Aug 26, 2024 | 09:43 AM
aklim's Avatar
aklim
I would test the battery first, clean the codes and drive. Ask any parts house guy. They have seen batteries that are bad out of the box.
Old Aug 26, 2024 | 11:37 AM
Chevyguy1980
5th Gear
Hi Lux, that makes sense from what I've been reading and what the smog techs told me. I've tested the battery and it's good. The codes will not clear through the scanner though, so I'll clear them by disconnecting the battery. Then I'll take a road trip with her and fingers crossed the CEL doesn't come back. Thanks for all the advice!
Old Aug 26, 2024 | 12:23 PM
aklim's Avatar
aklim
How did you test the battery?
Old Aug 26, 2024 | 12:46 PM
Chevyguy1980
5th Gear
After the CEL came on, I took it to AutoZone (Down the street from the smog station). Connected their scanner and that's when the codes P26C8 & P0711 came up. I had them test the battery as well, which came back fine. The next day I went back to AutoZone to see if their scanner could clear the codes, which it wouldn't. So I bought a scanner there that would. I hooked it up in the parking lot and that's when codes P26C8 and P12FD came up, but not P0711. I tried clearing the codes with the scanner I just purchased, only to learn that it couldn't due to the type of code. Now I will try clearing the codes by disconnecting the battery for 15 minutes.
Old Aug 26, 2024 | 01:16 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
These DTC's will NOT clear because they are stored in "Mode 10" in your scan tool...I'm not going to explain Mode 10 this right now but you can Google it...these are permanent codes and will not clear until those issues are fixed and the car had run and completed a drive cycle...Mode 10 was fully implemented in 2013 for any car....disconnecting the battery will not work.
Old Aug 26, 2024 | 01:24 PM
Chevyguy1980
5th Gear
Ok, thank you for letting me know
Old Aug 28, 2024 | 07:54 AM
Tinkertech's Avatar
Tinkertech
A lot of the monitors require a completely cold start, ie: engine shut down for at least 8 hrs or overnight, before the test will even start to begin.
To Check Engine Light - Please Help
