Stabilitrak Light ABS Wheel Speed Sensor
Old Sep 24, 2024 | 10:05 AM
reapr's Avatar
reapr
2nd Gear
Default Stabilitrak Light ABS Wheel Speed Sensor
Anyone ever had this issue.
It seems one of the rear wheels has difficulty accelerating above 3krpm. Lots of vibration
Old Sep 25, 2024 | 05:57 AM
Moved to C7 Tech.
Old Sep 25, 2024 | 10:36 AM
laserdude2215's Avatar
laserdude2215
Originally Posted by reapr
Lots of vibration
That's probably the ABS activating. Just about any shop should be able to diagnose and repair the fault.
Old Sep 29, 2024 | 06:18 PM
Bill Dearborn's Avatar
Bill Dearborn
Need more information. A8, M7? What gear are you in? Is the ABS light on solid or only when the problem is happening? If the ABS light is solid will need the ABS codes. If you don't have codes this is next to impossible to diagnose. You need a scanner that can read ABS codes Vs an OBD2-only scanner.
Bill
To Stabilitrak Light ABS Wheel Speed Sensor
