Jacking Pucks
Old Nov 8, 2024 | 11:36 PM
PuffyC's Avatar
PuffyC
I use
these these
from Amazon - $14 for a set of four. Just pop them in when you need to jack it up and with skirts and a low profile jack it clears easily. No need to spend more.
Old Nov 9, 2024 | 10:50 AM
KsChallenger's Avatar
KsChallenger
Thank you all for the kindness of your input. I have ordered a set from Amazon and will get them installed. They are designed to stay bolted in place once installed. I believe they will work well for me. Thanks again for all your help.
Old Nov 11, 2024 | 06:39 AM
TRED94's Avatar
TRED94
Active Streak: 90 Days
To prevent the bolts from backing out, add a drop of blue Loktite to each bolt during installation if they are to be left on the car. Using blue Loktite will allow the bolts to be removed later if needed.
Old Nov 18, 2024 | 12:40 AM
Avanti's Avatar
Avanti
ZL1Addons "permanent" aluminum. Even the form-fitting box they came in was exceptional.
Old Nov 18, 2024 | 09:03 AM
kodpkd's Avatar
kodpkd
Yep,,, the same ones on Amazon for $28.
Amazon Amazon
Old Nov 19, 2024 | 11:37 AM
boraxman's Avatar
boraxman
Been very happy with these myself...
Amazon Amazon
