Has anyone ever installed a remote kill switch/remote battery disconnect? I installed one on my c7 stingray and it works great however, when you turn it back on i have lost my clock settings and it also appears to loose the seat memory. Does anyone have and solutions or even a different disconnect switch that doesn't loose any car setting once it's disconnected?
The 1 i purchased was a (Gasory) brand from Amazon, my local corvette dealer didn't have any knowledge of installing any disconnects on a C7, thats why i went to Amazon as a 2nd choice.
You're better of using a remote controlled relay for the fuel pump control module. If they get it started it will run out of gas in 15-30 seconds. You won't lose any of your settings this way.
I installed a Mobilistic "No-Start" remote controlled relay in my C7, works great. Replaces the starter relay.
I like that it automatically arms whenever the car is shut off.
3 minute installation.
No codes or DTCs.
The relay things seems cool, but if the thief has entered the car, they can open the hood & trunk. What stops them from just pulling the relay & popping in the generic one?
Thinking like a car thief, I know my target car, & what can be done to stop me, wouldn't I just carry around spare relays? They are not specific to C7's & the same ones are used across many different cars thanks to universal standards.
It would have to be a guy w/ very specific knowledge of the relay. How to recognize the aftermarket one to start. And then he'd need to have a stock one in his pocket. Certainly not impossible but I'd think pretty improbable.
Nothing is fool-proof, but I think this will prevent 90% of theft attempts. For $100 and 3 minutes of installation time, I think it is worth it.
If the car doesn't start with some ECU/Immobilizer/FOB cloning hack that thieves use, there are many things that might be the reason that the car didn't start....not sure a thief is going to want to spend alot of diagnostic time finding out why...
i know this is close to a year old but wanted to see if you were still using the relay and if so, would you still recommend it?
also, i read that it automatically kicks on after the car has been off. Im guessing you just use the fob it comes with to disarm it?
We live in rural West Texas. As a rule, we don't need this. But staying in a hotel in Albuquerque over the weekend, I sure wished we had one. Fortunately, the car was still there both mornings...
Maybe rent a car or even a high end one if you have to worry like that? I parked my any one of my cars in the airport garage and my only worry is "Did I note where I parked so I can find it when I get home at night?". I have parked my wife's car, which is more expensive without any worry. As I asked her "If we have to worry, why do we pay insurance?".
