C7 Muffler Delete
what is the best option that ya’ll have done? Is it best to just remove mufflers, both cats, and turn off both sensors? Or smarter to leave them?
You can go straight pipe and remove the mufflers, I have done that but don’t recommend it.
I also can’t recommend a muffler unless you tell us if want it loud in cabin or just outside and if you want npp. If you don’t use the npp you just get adapter plates that bolt on to the actuators and zip tie them up. I have some I could sell you if you that route.
Personally I hate drone and would suggest the Corsa x and corsa extreme to retain the npp or the Borla x with the awe if you don’t care about npp. If you want it loud in the cabin and not just outside then you don’t want Corsa, go with awe. The extremes are loud but not inside.
there are plenty of other options but that’s my suggestion unless headers are legal where you’re located.
These couple things made my car louder for sure. The pipe makes it sound more "open" and with the valves being open the car is probably 10% louder if I were to guess. Hope this helps.
- There are four o2 sensors, not one
- Two o2 sensors....the fronts....are for fuel control
- Two o2 sensors....the aft sensors...monitor main cat efficiency, one per side.
- You can remove the secondary cats with Zero affect on the o2 sensors or the tuning since those cats are not monitored.
If you have the optional NPP mufflers, pull the fuse and the valves will be open all the time. Gives you about the same noise level as removing the mufflers without the hassle. Your hearing will thank me.
I have headers, bullet cats, and the factory NPP mufflers programmed to be open all the time in track mode. On the race track at WOT, it's fk'ing loud.
