part # needed
Old Nov 12, 2024 | 04:22 PM
9sec's Avatar
9sec
Default part # needed
what are these electrical blocks called? looking for part # for all of them if its possible
Old Nov 12, 2024 | 04:35 PM
MrHix's Avatar
MrHix
Here is some info from another member.
https://www.corvetteforum.com/forums...t-diagram.html
Cheers,
MrHix
Old Nov 12, 2024 | 04:46 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Best thing to go down to your Chevy dealer with your VIN number…I wouldn’t trust the internet.
Old Nov 12, 2024 | 04:48 PM
9sec's Avatar
9sec
I trust the guys on here over any dealer any day
Old Nov 12, 2024 | 04:50 PM
C5 Diag's Avatar
C5 Diag
OK, do whatever !!
Old Nov 12, 2024 | 04:52 PM
9sec's Avatar
9sec
Cheers,
MrHix
good info but doesnt list the p[art #
Old Nov 13, 2024 | 12:30 AM
PJO's Avatar
PJO
Veteran: Marine Corps
I do not think there will be a part number from GM as those items would be part of the wire harnesses. Most likely not sold separately.
Old Nov 13, 2024 | 09:24 AM
96GS#007's Avatar
96GS#007
You'll need to carefully examine the connectors for part number information and then buy them through someone like Mouser. I don't show those as being sold separately by GM. I'll dig around and see if I have docs showing the part numbers but the odds are pretty low.
The part numbers can be anywhere on the connectors as these examples show, and then you have to figure out the manufacturer. GM used a lot of different connector vendors on these cars....
Old Nov 13, 2024 | 02:28 PM
96GS#007's Avatar
96GS#007
I got curious and did some digging. The attached are the best I can find. Obviously you'll want to double check.
Looks like the brand is Yazaki based on the pins. Keep in mind that if you buy them, it's only the connector body. You'll need to de-pin your old ones
Example of what's in the docs...
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 13, 2024 | 04:28 PM
9sec's Avatar
9sec
awesome thanks!
To part # needed
