Antifreeze
Old Nov 28, 2024 | 09:19 AM
C746490's Avatar
C746490
Default Coolant disposal
What is the best way to dispose of used coolant? What is the best DIY coolant change steps to safely replace all of the old coolant with new.
Old Nov 28, 2024 | 09:32 AM
aklim's Avatar
aklim
Coolant isn't something an Autozone, Advance Auto, etc can accept, You are going to have to check with your local recycling center to see if they will or some place that does hazardous chemicals. Some repair shops might. Kinda why I won't DIY that. Draining the coolant and collecting all the coolant flushed out is no small task. I don't have enough containers to hold all the waste coolant plus flushed fluid.
Old Nov 28, 2024 | 10:12 AM
RonC7's Avatar
RonC7
I have taken used coolant to Walmart auto dept and a local tire / oil change place (some place that replaces coolant and has to recycle their own waste).
I keep a couple empty windshield washer fluid jugs in the garage for stuff like this.
No problems.
Ron
