Antifreeze
Old Nov 22, 2024 | 10:16 AM
C746490's Avatar
C746490
Default Antifreeze
I have a 2019 GS with 3000 miles and due to age do I need to replace the antifreeze? I have read different opinions and the pro and cons of doing all of the fluids and tires do to age. Is this a unnecessary expense or is it really needed?
Old Nov 22, 2024 | 10:31 AM
RonC7's Avatar
RonC7
GM spec Dexcool (orange) needs to be changed every 5 years per the maintenance schedule.
Correct mix is 40% Dexcool / 60% water down to -18 F and 50/50 below that. See your owner's manual.
Ron
Old Nov 22, 2024 | 10:54 AM
C746490's Avatar
C746490
Default Coolant life
Ron
I had read that and I assumed that it was time based not mileage. I was wondering what the C7 family was doing as a group.
Old Nov 22, 2024 | 12:19 PM
RonC7's Avatar
RonC7
Unless you know more than GM engineers or chemists follow the recommendations. Dexcool has been 5 year replacement on all of my GM cars for years.
Old Nov 22, 2024 | 05:02 PM
RacerRik's Avatar
RacerRik
I replaced mine last year on 2018 C7. Cheap insurance to prevent any internal corrosion problems. I used Dexcool with 40 / 60 mix using distilled water. The old stuff looked fine when I drained it. That is the key right there - you don't want to wait until the corrosion is starting.
Old Nov 22, 2024 | 11:18 PM
aklim's Avatar
aklim
On my owner's manual, I see 150K drain and fill scheduled. Note 4 says or 5 years, whichever comes first.
Old Nov 22, 2024 | 11:20 PM
aklim's Avatar
aklim
I'm not sure I would go with "look" to determine if the additives are still present in sufficient quantity. If you are doing a chemical analysis, that might be a different story.
Old Nov 23, 2024 | 12:41 AM
RacerRik's Avatar
RacerRik
I did not say I looked at the fluid and decided it looked good so I did not need to change it. I changed it because it was approaching 5 years old. I mentioned it looked fine to discourage others from making the mistake of saying it does not need to be changed because it looked good.
A chemical analysis would likely cost more than I spent to change it. I bought two gallons of Dexcool concentrate and three gallons of distilled water. Total cost was under $30. I will do the same thing again in 4 years or so. And the cost will probably be $60 - thanks to inflation. I still don't know how things seem to double in price over just a few years when they keep telling us inflation is not bad.
Now if it does start to look cloudy or off color, I will certainly change it sooner. But I doubt that will happen because Dexcool is a proven product.
Old Nov 23, 2024 | 01:01 AM
aklim's Avatar
aklim
Pretty much what I was getting at.
For $45, it is more than just the cost of materials. However, it gives you insight to how things are progressing in your system.
I would suspect that if it really looks cloudy or is off colored, things are really far along.
Old Nov 23, 2024 | 04:06 AM
Z06_racer's Avatar
Z06_racer
The coolant on my Z06 from 2019 would now have to be changed after 5 years and I'm wondering whether that's really necessary. For other vehicle brands there is no requirement to change.
Old Nov 23, 2024 | 08:11 AM
aklim's Avatar
aklim
What vehicle do you have that doesn't ask for coolant service?
Old Nov 23, 2024 | 12:02 PM
Z06_racer's Avatar
Z06_racer
With my Audi, for example. I don't know that there is any provision for changing the coolant. Certainly not after 5 years.
Old Nov 23, 2024 | 01:40 PM
RonC7's Avatar
RonC7
It's all a matter of the coolant chemistry. I can recall changing coolant every 2 years when I was growing up (1964 Chevy BelAir). GM changed the coolant to Dexcool (orange) in 1996 and was good for 5 years. My new Subaru says blue coolant is good for 11 years. But Subie recommends oil changes every 6 months. Go figure...
Ron
Old Nov 23, 2024 | 07:22 PM
aklim's Avatar
aklim
I haven't owned my A8 for a year so not totally used to it yet. I did get the fluids flushed since it was new to me. I will have to look into that with Audi as to why they don't have a flush interval.
Old Nov 23, 2024 | 08:59 PM
RonC7's Avatar
RonC7
Guys,
Look in your owner's manual or online. The info is out there.
Audi recommends changing the coolant in your vehicle every 60,000 miles or four years, whichever comes first. However, the frequency of coolant changes can depend on a number of factors, including:
  • Driving conditions
    If you drive your Audi in extreme temperatures, you may need to change the coolant more frequently.
  • Type of coolant
    Audi's proprietary coolant is designed to last longer, but other coolants may need to be changed more often.
  • Sediment buildup
    Even with approved coolant, sediment can build up over time. Draining the coolant alone isn't enough, as up to 50% of the old coolant can remain in the engine block
Old Nov 23, 2024 | 09:25 PM
aklim's Avatar
aklim
Guys,
  • Type of coolant
  • Sediment buildup
IDK. I just checked my online manual. It lists checks every so often but nothing about draining it and this is up to 200K. This is for a 21 A8 with the TFSI 60. Like I said, when I get a used "new to me" car, it flows, it goes. Since I have a warranty with the purchase, I would prefer not to get on their bad side by being naughty.
Old Nov 23, 2024 | 09:32 PM
RonC7's Avatar
RonC7
OK - I'll take your word for it. Seems you can't access an online manual without a VIN. I doubt that I'll wait 11 years on my Subies either.
Ron
To Antifreeze
Old Nov 23, 2024 | 09:50 PM
aklim's Avatar
aklim
Ron
You don't know the other half of it. You aren't an owner so no access to the super secret manual for peasants like you. I have an app that can access the manual. Pretty cool, huh? You get to enter your VIN in EVERY SINGLE TIME you want to access something. You can't download it because Audi needs to keep such sensitive information from the unwashed masses. You want to look up anything and you get to enter the VIN again. So say you do that, look up the info and close it out? Nope. Enter the VIN in again. So, being smarter than most, I do that and leave the window open for the next time. Should be easier, right? Nope. Time Out if you don't use it. SERIOUSLY? Are you going to ask me for a retinal scan? Maybe DNA sample? WTF!!
Old Nov 25, 2024 | 06:22 PM
Bill Dearborn's Avatar
Bill Dearborn
I have owned several GM vehicles over the last 30 years. Each one was in my possession for more than 5 years with some going through multiple 5 year changes. My 2003 Tahoe had its 4th coolant change last year. The vehicle is still on all of its original cooling system components, hoses, radiators, heaters, water pump and any pipes attached to the hoses. It has about 130 K miles and is used as a tow vehicle for the Vette when I take it to the track. My 2015 Z06 will see its second coolant change next year and I have a 2024 Cadillac Lyriq with the same cooling system requirement (yes they need a cooling system to cool the battery). My anecdotal experience is changing the Dexcool every 5 years is a key maintenance item. Each time I have changed the coolant the old coolant looks almost the same as the new coolant which is something that I find interesting as I remember before Dexcool was introduced and changing the old green fluid every two years was a necessity with the drained fluid no longer looking green.
Bill
Old Nov 25, 2024 | 08:44 PM
aklim's Avatar
aklim
My thought is that back in the day, things are less sophisticated. Car running rough, something is wrong and one of a few things that it could be. Today, cars, IMO, run great even when there are issues UNTIL THEY DON'T. Back then, smell, touch, sight and hearing was fine for diagnosis. Today, it isn't. IAT was all there was. If it was green, it is coolant. Today, you have OAT, HOAT, N-OAT, etc, etc. Probably the easiest way is to use test strips.
Back in the day, my 01 Excursion with the 7.3 Powerstroke diesel had the IAT coolant because Ford didn't want to use the ELC that International wanted to use. I mean, Ford bought that engine from International, what would they know. So you used the IAT coolant and added additive every 15K. Look all you want but you can't tell the difference when I put it in or not. I drained it all and replaced it with the ELC that was recommended. Why? So I don't have to keep adding additives to bring it barely up to par. Instead the ELC was way better and didn't need changing for 300K.
