Door locks.
Old Nov 23, 2024 | 03:07 PM
kodpkd's Avatar
kodpkd
Default Door locks.
I just figured out, when you lock the car and walk away, then return to the car, you don't have to unlock it. The car knows you are coming back to get in and unlocks it.. Each time you walk away though, you have to lock it.
Is this a DUH!
Old Nov 23, 2024 | 04:07 PM
KLG's Avatar
KLG
Is this a DUH!
Interesting, I did not know that was an option.
I have Passive Door Locking enabled on mine. When I exit and all doors and hatch are closed, the car automatically locks a few seconds later, at the same time, the horn beeps once and the parking lights flash once. To unlock and open the door, I must touch the door handle sensor.
Regards,
Old Nov 23, 2024 | 07:06 PM
kodpkd's Avatar
kodpkd
When you say "door handle sensor", you mean the normal door open button?
Old Nov 23, 2024 | 07:20 PM
KLG's Avatar
KLG
Yes, that's it.
Old Nov 23, 2024 | 08:32 PM
RonC7's Avatar
RonC7
The door unlocks when you press the door pad and there is a fob in range... You don't have to push the unlock button on the fob. You can configure to only unlock the driver's door or both. Go through ALL the settings and you'll learn a lot.
DUH! is right.
Old Nov 24, 2024 | 09:12 AM
kodpkd's Avatar
kodpkd
Yes, not having to push the unlock button is my point.
Old Nov 24, 2024 | 04:10 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Regards,
I tried that but I don't like the car locking itself in my garage. Means I have to get key every time I just want to go out to it and open a door. Just as easy to hit the lock button twice on the way out of the car when I want it locked. Do that with my truck also as it doesn't have the passive feature.
Old Nov 24, 2024 | 05:36 PM
KLG's Avatar
KLG
Agree, that can be annoying if the cars locks and you do not want it locked.
However, when I park in my garage, before I exit, I press the unlock button until the car chimes 3 times, then the Passive Lock feature is disabled until the car goes through another engine start/stop cycle.
Regards,
Old Nov 24, 2024 | 06:02 PM
F4Gary's Avatar
F4Gary
Regards,
Did not know that.
Old Nov 24, 2024 | 10:44 PM
C5FORFUN2's Avatar
C5FORFUN2
Must be an option setting. I didn't want mine to auto lock (or the stupid horn honk) so I set it not to, but kept the auto unlock. Just walk up with the fob in a pocket and open the door.
Old Nov 24, 2024 | 11:01 PM
aklim's Avatar
aklim
Regards,
Your way sounds better. Not that I ever do that. I just let it auto lock every time. I don't usually go to the car when it is in the garage unless I am driving it, in which case, I need to have the key. It is nice to have it auto lock so that when you walk away after parking it at someplace, it locks for you. No forgetting. Best of all, I don't have the wife asking me if I locked the car.
Old Nov 25, 2024 | 08:52 AM
kodpkd's Avatar
kodpkd
I thought it was more of an, auto unlock, than an auto lock.
Old Nov 25, 2024 | 09:33 AM
aklim's Avatar
aklim
I would say that it can be both. Soon as I hit drive gear, it locks. Walk away for 10 seconds, lock.
Old Nov 25, 2024 | 10:47 AM
kodpkd's Avatar
kodpkd
Yes,,,, when you start driving, the doors lock automatically, but on the 2014 there isn't another, auto lock mode. When you get out of the car you have to hit the key fob lock for the doors to lock.
EDIT:
OOOOH! I am wrong! I found the, passive door lock feature, walk away, horn honks, and locks the doors. Even on the 2014
Old Nov 25, 2024 | 02:05 PM
CraigStu's Avatar
CraigStu
EDIT:
Not sure on a 14 but my 19 has lock and unlock buttons on the door. I use that to lock the doors when I leave the car. I really never touch the fob.
Old Nov 25, 2024 | 02:21 PM
aklim's Avatar
aklim
You don't have to, I don't
Old Nov 25, 2024 | 04:34 PM
kodpkd's Avatar
kodpkd
How do you lock the car when you park it without using the auto lock function or the remote?
To Door locks.
Old Nov 25, 2024 | 05:05 PM
aklim's Avatar
aklim
Old man way. Unlock the door, open the door and lock it and step out and close the door.
Old Nov 25, 2024 | 06:18 PM
F4Gary's Avatar
F4Gary
I just press the lock button on the door. I have press it twice. It beeps the first time I guess because the fob is still in the car, and then locks the second time.
I'm going to try the hold the lock button for 3 beeps with the setting on passive lock.
Old Nov 26, 2024 | 11:19 PM
bearone2's Avatar
bearone2
when i arrive at the gym @ 500, i leave the fob in my pocket, walk away horn toots!! access to gym is with house key....separate from fob!!
when i come back from the gym @ 600, i lock with the fob before walking away, no toot of the horn, don't wake anybody up in mine or neighbors house!!
