Driven DI40 Oil question
Old Dec 11, 2024 | 08:29 AM
Habeas Corpus's Avatar
Habeas Corpus
Default Driven DI40 Oil question
I’ve been using Driven DI40 0w40 and noticed they replaced part number 18406 with 5w40. Has Driven discontinued 0w40? Thanks.
Old Dec 11, 2024 | 09:05 AM
kodpkd's Avatar
kodpkd
The 0W vs 5W is just a temperature rating. If you live in a warm climate the 5W would be ok.
Old Dec 11, 2024 | 03:30 PM
Bill Dearborn's Avatar
Bill Dearborn
It would be fine in a cold climate as well. 5W oil will work perfectly well in below 0 deg F temps.
Bill
Old Dec 11, 2024 | 07:29 PM
kodpkd's Avatar
kodpkd
I don't disagree, but he was concerned about the 5W-40. If you had to pick an oil for cold climates, it would be the 0W-40
Old Dec 12, 2024 | 09:49 AM
kodpkd's Avatar
kodpkd
https://www.summitracing.com/parts/j...waAt5TEALw_wcB
Does this have Dexos?
Old Dec 12, 2024 | 10:31 AM
Habeas Corpus
Okay I just spoke with a Driven Oil sales rep and confirmed a few months ago they switched DI40 0W40 to 5W40. Thanks everyone.
Old Dec 12, 2024 | 02:52 PM
kodpkd's Avatar
kodpkd
It appears you race your car. Pretty sure you are not racing in 0*F or even 5*F. I am also sure you warm your car up before you get on it. So a multi temperature oil isn't a big deal.
Old Dec 12, 2024 | 05:02 PM
CPB's Avatar
CPB
The winter grade of the oil has more to do with the startup protection.
Old Dec 12, 2024 | 06:42 PM
kodpkd's Avatar
kodpkd
yes, of course
Old Dec 13, 2024 | 10:48 AM
2019GSTX's Avatar
2019GSTX
Lurker
St. Jude Donor '19-'20
Please read this article by Driven.
Dont get me wrong. I have been running Driven DI 0w40 in my engine since the day I picked it up from the shop after having a cam installed. No issues at all. Not knocking the brand at all.
I was surprised when a friend, who also had the same work done, ran across this article and sent it to me.
For clarification, I havent tracked the car since the engine work was done and I dont daily drive it but I think I will change back to Mobil 1 at the next oil change.
Your circumstances may be different than mine so I'm just offering the link as insight for those considering Driven. YMMV.
https://drivenracingoil.com/n-2-why-...e26FLP3_1HzJZq
Old Dec 13, 2024 | 11:08 AM
kodpkd's Avatar
kodpkd
So many people think they are using, super duper magic, oil in their car, then have issues. Mobil 1 full synthetic 0W-40 is great oil, with the required Dexos, recommended by GM. Racers might even use 50 weight oil in their cars, but not good for a normal car.
Old Dec 13, 2024 | 11:56 AM
CPB's Avatar
CPB
I thought the issue is the additive package, specifically detergents. Wouldn't a -50 with the correct additive package be fine for street usage? The DexosR for the lt6 comes to mind.
Old Dec 13, 2024 | 12:08 PM
kodpkd's Avatar
kodpkd
I wouldn't run it. It's to thick. GM says 40 weight oil. These newer Corvette engines are designed with closer tolerances and need the correct oil.
Originally it was 35 weight oil and they raised it to 40 weight.
Old Dec 13, 2024 | 12:23 PM
CPB's Avatar
CPB
Why would it being -50 cause a problem? I've never heard reason not to move up viscosity aside from potential MPG impact.
My -50 UOAs look great with very low PPM of metal wear.
Old Dec 13, 2024 | 12:57 PM
kodpkd's Avatar
kodpkd
What about 60 weight or 80 weight oil. A lot of wear happens at start up when the engine is cold, even worse with thick oil. That's why they went to multi viscosity oils. A little bit lower viscosity when at low temp, normal viscosity at normal temp. Don't forget viscosity is different than weight. Every given weight oil has a full range of viscosity, depending what the temp is. All oil has thicker viscosity at cooler temps than when warm. Oil NEVER gets thinner when cold.
Old Dec 13, 2024 | 01:17 PM
CPB's Avatar
CPB
I'm referring to a 5w50. The W is for "winter" not "weight." The second number is viscosity (flow) at 100C. The DexosR 5w50 has more viscosity modifier relative to base oil than something like a 20w50.
GM even says that the -50 is fine, so I'm curious what evidence you have where increasing viscosity is causing a problem. https://www.gmdexos.com/brands/dexosr/index.html
Old Dec 13, 2024 | 04:28 PM
kodpkd's Avatar
kodpkd
I totally understand what w stands for, and 50 is the weight not,,,, viscosity. I also understand what is recommended for the C7, and it isn't 50 weight oil. Of course GM recommends 50 weight oil, but not for the C7. Or if you are tracking your car and "needs to be removed".
File Type: pdf
To Driven DI40 Oil question
Old Dec 14, 2024 | 09:56 AM
Internets_Ninja's Avatar
Internets_Ninja
It's simple. Thicker oils have less cold start protection. Most of all engine wear occurs at cold start. Running a 5w50 oil on a stock internal engine, for daily driving, is foolish and you're just doing more harm than good. Even with a cam and bolt ons, follow GM's recommendations for oil weights/viscosity.
Old Dec 14, 2024 | 11:35 AM
kodpkd's Avatar
kodpkd
This is a great websight. Compares viscosity at all the temps compared to weight, and higher weight vs lower weight oil.
https://wiki.anton-paar.com/en/engine-oil/
Old Dec 15, 2024 | 01:59 PM
CPB's Avatar
CPB
I think you mean viscosity and not weight. https://bobistheoilguy.com/putting-t...nto-viscosity/
The only reason the -50 would need to be removed would be to hit MPG/Emissions targets.
