Battery Replacement
Old Jan 24, 2025 | 03:59 PM
MissileDoc's Avatar
MissileDoc
https://drivinvibin.com/2023/09/09/w...cle-batteries/
Old Jan 24, 2025 | 04:27 PM
Blackwater0323's Avatar
Blackwater0323
Originally Posted by AndyCBR
I used an Interstate from Costco. It had the vent tube port and came with the plug in a plastic bag also.
There are only a few companies who actually make batteries anymore.
The Costco Interstate is made in Mexico.
The Walmarts and Autozone are made in China.
I really don't know who makes the AC-Delco ones for Chevy.
East Penn (Deka, Yuasa NA) is one of the few battery plants left in the US.
Just did the same this week for my 2019. $124 for the wet cell Interstate. Has a few more CCA than stock. Thought about the AGM for $179, but my GS sits on a maintainer and the original lasted 6 years. Changed it because I did not want to possibly get stranded this year.
Old Jan 26, 2025 | 05:51 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
This past week I had to replace the battery in my 2020 Yukon after it got down to the teens here in Houston, Texas. And that's COLD for here. And the kicker is that I had replaced the original on 18Sept2024 with a Diehard Platinum. Now the Diehard battery USED to have a good reputation for a good battery...not so much anymore. Then I took the battery back to Advance Auto in my 2017 GS with its 8 year old original battery. I think when it comes time to replace the battery in the GS that I will go back to the Delco battery.
Old Jan 26, 2025 | 06:09 PM
aklim's Avatar
aklim
I don't know about the Yukon but the C7 is not stuck in the engine bay which gets freezing and blazing hot cycles. Also I doubt you pamper the Yukon battery as much as the C7 so that might change the longevity.
Old Jan 27, 2025 | 07:52 AM
Tinkertech's Avatar
Tinkertech
Be aware of Walmart factory OEM parts for lot of them are not.
The scammers have made the boxes and filters look just like OEMs but one detail they could not produce is the small round hologram that Toyota puts on every box. No hologram = counterfeit and also check out the hologram, if it looks not quite right, pass. Also the printing on the box and filter was a bit fuzzy.
Bought 4 filtered from Walmart and 3 did not have the hologram, returned them all and purchased the OEM filters at Toyota which all had hologram stickers.
Old Jan 27, 2025 | 04:34 PM
Sleazy Rider
I also put a Diehard Gold battery into my 91' C4 ZR-1 last fall and it also would not start after our deep freeze. It also has the battery in the engine compartment and while it showed a couple volts when I put the charger on it, it took the charge and I took it on my club's road run this past Saturday. Supposedly an inferior battery to the Diehard Platinum, but it survived.
Old Jan 27, 2025 | 10:37 PM
JLSuperfly's Avatar
JLSuperfly
Is it replacing a C7 battery a DIY job?
This is coming from a guy who took nearly an hour to replace the engine air filter.
Old Jan 27, 2025 | 10:43 PM
AndyCBR's Avatar
AndyCBR
I think so. Biggest challenge is gaining enough access to the battery area without tearing up your rear carpet. The only real way to do it IMHO is to pull the rear carpet, if you just tug and fold it over on the corner you have a very high chance of tearing it (which doesn't bother a lot of people).
Do some research on pulling the rear carpet and after that the job is very straightforward. Take care and pull the negative terminal first and avoid shorting across terminals with any metal tools and you should be OK. There are some good (and not so good) youtube videos out there,
Old Jan 28, 2025 | 12:09 AM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by C5FORFUN2
Go with the correct AC Delco. I found better prices at the Chevy dealer than auto parts stores as well as a better warranty. Another thing to think about when you hear the ditty about batterys being made by the same manufacturer. It's not about who makes it, it's all about who it's made for.
That is what I did last year. I purchased a Delco Gold 42 month warranty battery from my local dealer. They were having a special on them when my original went bad. They charged $60 more than OReilly's would charge for the same battery and installed it. The Auto Parts stores in my Area will not install a battery in a C7. I also got the battery installed the same day I took it in. I had to order the battery at OReilly's.
By the way, the C7 Charging system isn't compatible with AGM batteries. It applies a voltage at least a half volt higher than what an AGM battery is designed for.
Bill
Old Jan 28, 2025 | 01:05 AM
AndyCBR's Avatar
AndyCBR
My understanding is that the C7 charging system will actually slightly undercharge an AGM battery versus the flooded wet cell battery.
Whether this actually matters or not, or would result in the service life of an AGM being less than that of a wet cell, is a matter of great debate and is not settled science.
Many Vettes stay on tenders, which is a good idea regardless of battery type, so as long as your tender is AGM compatible you will reach max voltage. I say go for it if you want the obvious advantages AGM's bring. If not, wet cells are available also.
In experience there doesn't appear to be many C7 (or C6 or C5) owners complaining about short AGM battery life and there are plenty out there with AGM's in service.
Old Jan 28, 2025 | 06:29 PM
Bill Dearborn
It may slightly undercharge the battery from a SOC standpoint but the charging system is designed to provide a higher voltage than desired for AGM batteries. It isn't based on a simple voltage regulator as seen in older cars. It is designed to maintain a SOC on a wet-cell battery. Here are the relative pages from the FSM:
This is the info on how AGM batteries should be charged:
The typical charging voltage for an AGM battery is between 14.4 and 14.8 volts when fully charged, with variations depending on the battery's specific characteristics and temperature; this voltage is usually reached during the "absorption" stage of charging, while the "float" stage maintains a slightly lower voltage to prevent overcharging, around 13.6-13.8 volts.
Key points about AGM battery charging voltage:
  • Important considerations:
    Using a charger designed specifically for AGM batteries is recommended to avoid damaging the battery by applying excessive voltage. !!!!!!!!!
  • Charging stages:
    AGM batteries go through three charging stages: bulk (high current, rapid charging), absorption (near full charge, voltage maintained), and float (maintenance charge at a lower voltage).
  • Temperature compensation:
    The ideal charging voltage can adjust based on battery temperature, requiring a charger with temperature compensation features.
Bill
Old Jan 28, 2025 | 07:12 PM
AndyCBR's Avatar
AndyCBR
"Whether this actually matters or not, or would result in the service life of an AGM being less than that of a wet cell, is a matter of great debate and is not settled science."
Excellent detailed info above. But the fact remains there is no conclusive real world data that shows AGM's experience poor service life in C7 (or C5, or C6) Corvettes.
Cheers.
Old Jan 29, 2025 | 01:17 AM
  #33
Bill Dearborn
Cheers.
Why take a chance? Good Data indicates it could be a problem. There also isn't a lot of real-world data that indicates AGM batteries last any longer in a Corvette application than well-maintained standard batteries. There is also a paucity of data when it comes to whether there is sufficient extra lifetime to justify the extra cost of purchasing an AGM battery. That leaves you with the potential of damaging a higher-priced battery that doesn't provide any extra durability.
Bill
Old Jan 29, 2025 | 07:17 AM
  #34
AndyCBR's Avatar
AndyCBR
Bill
Great discussion Bill!
My belief is there is no real chance of "damage". If there is any real world data to support the theory of poor service life or "damage" from AGM's installed in a C7, C6, or C5, please post it.
-AGM construction has the most obvious advantage of eliminating possible leaks or spills versus wet acid models. This is not to be understated once the battery is mounted inside a passenger compartment.
-AGM batteries are less likely to spill and catch fire in a collision.
-Many users report longer life from AGM batteries, in general, that would likely be impossible in a wet cell. It's simply a more modern and durable design overall and becoming the standard in many makes and models from the factory. It likely won't become the standard for all makes and models though, mainly due to cost.
-The wet cell failure modes of mounted plates coming loose or settled piles of sulfate shorting out the plates from the bottom is eliminated. AGM's can sulfate though (albeit, at a slower rate than wet cell)
-AGM batteries have a lower self discharge rate than wet cell batteries.
-AGM batteries perform better in cold conditions.
It's just a better mousetrap overall. I believe C7 owners can take advantage of that even with a charging system that wasn't designed specifically for the AGM.
Old Jan 29, 2025 | 08:01 AM
  #35
aklim's Avatar
aklim
Don't they also have better charge holding abilities so you can store your car longer without having to screw with a charger?
Old Jan 29, 2025 | 01:58 PM
  #36
AndyCBR's Avatar
AndyCBR
Yes, the item above that states a lower discharge rate effectively means just that.
In the case of any occasional use vehicle it is really best to have it on a tender when not in use. In the case of the C7 with an AGM I think it is probably even more relevant since it is true the C7 charging system will not get an AGM up to 100% charge by itself. Now, does it get it to 89%, or 92%, or 96%? I have no idea, and I posit that it doesn't really matter.
It's an individual choice, and for me, I chose the Costco/Interstate AGM for $169.99 + tax at the time.
