Battery Replacement
Old Jan 22, 2025 | 03:59 PM
Rvajma's Avatar
Rvajma
Default Battery Replacement
Battery died and I finally got in the trunk since my tumbler is loose. Any particular suggestions as to what to replace it with? Advance Auto shows a Die Hard Gold or an Optima 800cca which costs about 50% more. Does it really matter? Input welcome.
Old Jan 22, 2025 | 05:48 PM
MissileDoc's Avatar
MissileDoc
Check out the Walmart AGM.
EverStart Platinum AGM Automotive Battery, Group H6 / LN3 / 48 12 Volt, 760 CCA
Lots of Walmart stores around if you ever need warranty coverage.
Old Jan 22, 2025 | 06:25 PM
96GS#007's Avatar
96GS#007
If you do a search, you'll find this has been discussed probably a dozen times in the last couple of months (and hundreds of times over the last 10 years), you can get any answer you want, and it always turns into a religious discussion.
Old Jan 22, 2025 | 07:21 PM
Rvajma's Avatar
Rvajma
Thanks, appreciate it.
Old Jan 22, 2025 | 07:26 PM
Rvajma's Avatar
Rvajma
P.S. looks like a much better deal than Advance Auto, thanks for the tip.
Old Jan 22, 2025 | 09:59 PM
C5FORFUN2's Avatar
C5FORFUN2
Go with the correct AC Delco. I found better prices at the Chevy dealer than auto parts stores as well as a better warranty. Another thing to think about when you hear the ditty about batterys being made by the same manufacturer. It's not about who makes it, it's all about who it's made for.
Old Jan 22, 2025 | 10:27 PM
aklim's Avatar
aklim
People like to think that they can get a product that is sold at $100 for $50 with a different sticker. Sometimes, it works out but not always. Maybe I'm just unlucky and most of the hacks I use go south.
Old Jan 22, 2025 | 10:30 PM
fuzzy03cls's Avatar
fuzzy03cls
I use walmarts on my cars. However nothing wrong with he stock AC Delco gold one. And most dealers run specials on them. Stay away from optima.
Old Jan 22, 2025 | 10:36 PM
aklim's Avatar
aklim
Don't know about Optima but I have used Odyssey on my F250 and it seems OK so far. So far, I have little faith in the quality of anything branded for WalMart. Maybe batteries are the exception but while I shop at WalMart, I only buy branded stuff that isn't WalMart.
Old Jan 22, 2025 | 11:44 PM
JLSuperfly's Avatar
JLSuperfly
Did the dealer charge you for the install and if so, how much?
Old Jan 23, 2025 | 05:37 AM
aklim's Avatar
aklim
I'm sure they will. Probably an hour?
Old Jan 23, 2025 | 10:29 AM
Tinkertech's Avatar
Tinkertech
Off brand from OEM is always manufactured to a certain 'price point'.
Build integrity and quality follows.
Old Jan 23, 2025 | 12:21 PM
C5FORFUN2's Avatar
C5FORFUN2
I purchased it from them, but installed it myself.
Old Jan 23, 2025 | 12:56 PM
aklim's Avatar
aklim
I tend to believe that. OTOH, it flies in the face of the concept of the hack where you can get $100 items for the price of $50.
Old Jan 23, 2025 | 09:42 PM
Photomania's Avatar
Photomania
I remember when I could get a car battery for $30 and they lasted three or four years. I bought a battery for my wife’s car a few weeks ago and it was $234 for a three-year Diehard at Advance Auto.
Old Jan 23, 2025 | 09:51 PM
aklim's Avatar
aklim
I also remember when the minimum wage was way lower. $3, IIRC in the 80s.
Old Jan 24, 2025 | 01:39 PM
Last time I changed the battery in mine I went with an AC Delco available at my dealer. Has worked just fine for five years so far.
To Battery Replacement
Old Jan 24, 2025 | 03:26 PM
AndyCBR's Avatar
AndyCBR
I used an Interstate from Costco. It had the vent tube port and came with the plug in a plastic bag also.
There are only a few companies who actually make batteries anymore.
The Costco Interstate is made in Mexico.
The Walmarts and Autozone are made in China.
I really don't know who makes the AC-Delco ones for Chevy.
East Penn (Deka, Yuasa NA) is one of the few battery plants left in the US.
Old Jan 24, 2025 | 03:53 PM
aklim's Avatar
aklim
Can I not make a product to different price points? I have done it before. You tell me you are willing to pay $200 a ton. I tell the factory to make it 50% active ingredient, 50% filler. You want to pay $250 a ton, I make it 75% active ingredient and 25% filler. All of them will be in whatever bag you want from the same location.
Old Jan 24, 2025 | 03:57 PM
AndyCBR's Avatar
AndyCBR
Lighten up Francis
It’s an open forum. My opinion is COO and quality of construction has some bearing here and you aren’t just paying “by the pound” for a battery.
With that said, there are very few real choices for conventional batteries regardless of the sticker on the side.
