Soler thottle body/add throttle body controller
So here is my timeline, first I did the throttle controller and was not thrilled, then I got the throttle body and I was still not thrilled. No matter what I tried, the results were a compromise at best. There seems to be an off idle transition that happens awkwardly in the OEM environment. The sport settings and the throttle controller didn’t seem to do the trick. It was only when I adjusted the settings into the eco (negative 3) range that things began to improve. It seems that slowing (rather than speeding) the throttle action through this transition delivered the drivability that I was after. Interestingly, the throttle response and power beyond idle are excellent, the power isn’t reduced, it just comes in later. One final thought, I’m not sure if the car learned over time or if I adapted but it’s really quite nice these days. I located the throttle controller in the center console so rowdiness is just a twist of the dial located at my elbow. I’d get the controller first then go for the throttle body second. Make sure that the controller that you select has several eco modes. JMO.
With the throttle controller you can change the rate at which the throttle plate moves through the “choke” zone.
With the throttle body, the alterations to the throttle body itself can potentially diminish and/or eliminate the choke zone.
I tried the Vitesse throttle controller first. Speeding up the controller changed the character of the choke but didn’t eliminate it. It also made slow speed driving in traffic difficult at times because the throttle opened more abruptly. I never tried putting the controller in the eco mode which would have SLOWED the throttle action down as it passed through the choke zone because all the on line solutions suggested that speeding up throttle response was the answer.
I then purchased a Ported Solar Throttle Body. It is a nice quality piece by all appearances but it didn’t seem to have much effect on the choking issue.
At that point I kind of gave up and just lived with it. I really was really wasn’t enjoying the car that much. I love the low effort of the hydraulic clutch but, I struggle to feel the “friction point” of clutch engagement and when you combine that with the problematic tip-in cough it really wasn’t much fun to drive in heavy traffic. At some point, tiring of the abrupt throttle response in Sport 3 and just playing around, I put the controller in Eco 3. It was a busy day and I didn’t give it any more thought. The car is not a daily driver and sees only sees occasional use, so it was only some time later that I realized the choking problem seemed to have gone away. I have made no further investigations such as trying different combinations of parts or settings. My recommendation is to start with a throttle controller that offers an Eco or slow down function so you can try speeding up or slowing down throttle response. And review your results, if the problem persists try the throttle body. Eco 3 mode didn’t seem to reduce power, only how abruptly it arrives.
Good luck.
It's your car and your decision but, if I were you, I'd try the less expensive and simple solution(s) before jumping into a more expensive and complicated one.
The throttle table shows how much the throttle blade opens....regardless of how far the gas pedal is pushed down...throughout the rpm range. There are also torque based tables (2nd screenshot) that are for Driver Demand. You can see how it's a smooth ramp. Make it steeper and you have faster throttle response and vice versa. These tables also account for what gear the transmission is in so there's more to it than I'm showing. Mike can offer up the real answer but I'll presume that the throttle controller fibs the throttle position to affect the driver demand tables.
As an aside, I think GM limited throttle opening in an attempt to reduce the cases of "too much car / not enough driver". Just a guess.
The flat spot people often cite is likely due to the VE coefficients. On the left side of the first screenshot is the 3D view of the factory Virtual VE table. The area I circled in red is roughly where the flat spot happens. Why GM didn't smooth this table, I have no idea. They have pretty smart folks so I can only surmise the juice wasn't worth the squeeze.
There are many other things going on so the below is a very simplistic display of a little of what's behind the curtain. It's pretty amazing what the Engineers accomplished and to think that much of this was started 12+ years ago makes it even more impressive.
Driver Demand
Anyway.....
Went on a drive today, she was a real sweetheart. I checked my setting, it was on Eco 5 yet she still responds aggressively when you give the pedal a stout wack.
Took less than 10 minutes and no tools. Nice!
A throttle controller adds no additional power, it just operates the throttle more aggressively. The LT1 has buckets of low speed torque so snapping the throttle open delivers big results no matter if the throttle is snapped open with your foot alone or with the aid of a throttle controller.
