C7 odd throttle behavior?
Old Feb 12, 2025 | 08:30 AM
Trex1331's Avatar
Trex1331
Cruising
Default C7 odd throttle behavior?
I have 14' stingray z51 7 speed and I'm having an odd behavior with the throttle when I first start out. The car starts to pulse the throttle and starts bucking with even pressure on the pedal.
if I let out it will stop but if I go back in to it almost immediately it will do it again. This doesn't happen everytime
I have a Soler throttle controller installed and wondering if this may be causing the issue. Haven't had a chance to test that theory as I haven't been able to get free time with it again. This issue wasn't there prior to the install so I'm wondering if I may have a bad throttle controller unit. I've reached out to Soler and waiting to hear back from them.
Another theory I have is maybe the wider tires I was able to go with and the traction control is engaging because of it.
I was able to stuff z06 width tires on my stingray front - 285/30/19
rear - 335/25/20.
I'm just trying to get some insight on what may be the cause this if anyone else has had similar issues. before I'm able to start doing some troubleshooting
Old Feb 12, 2025 | 12:23 PM
NortonCO's Avatar
NortonCO
Definitely not normal for Soler TC. I've had two of them in two different cars and never experienced this issue. Always a possibility you got a bad one, but I'm sure Soler will sort that out, if the case. Can't speak to the rest of your setup. Good luck!
Old Feb 13, 2025 | 09:02 AM
Tinkertech's Avatar
Tinkertech
Just remove the controller and see if the issue goes away.
If it does, then you have your answer.
If not, leave the controller off and keep trouble shooting.
Old Feb 13, 2025 | 09:15 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Appreciate you reporting this pulsating throttle concern here. We can imagine the concern this brings and the desire for some answers. If you don't receive the information you need here, we do recommend asking your local Chevrolet dealership on what they might think is the cause for this. Should you need help connecting with a dealer, our support team can be reached via email at socialmedia@gm.com.
To C7 odd throttle behavior?
