Brake fluid flush questions
As to how much fluid to buy, I use about 2 quarts. I suck out all the fluid in the reservoir, pour some back and suck it out. Not sure I want to mess around with pulling out the reservoir to get rid of any sediment at the bottom. I flush out all the fluid out of each line and then a bit more. Consider 8 bleeder screws so over a quart. Might as well buy 2. If you only use 1, return the other.
Please DON'T use the supplied RED Metal cap, it will destroy the locking lugs on your reservoir, ask me how I know.
Just write to Motive and they will send you a new cap, Black Plastic, and try that. I received one but of yet not tried it. Might have to modify it so it does not contact the locking lug on the reservoir.
Good luck.
Good luck.
What do you guys/girls think of this?
Amazon.com: Orion Motor Tech Pressure Bleeder, 2.5L Pressure Brake Bleeder Set with 49.5mm Adapter, 2.6qt Manual Power Brake Bleeder with 500mL Brake Bleeder Bottle Compatible with GM Models Chevrolet Chrysler : Automotive
It looks like the similar one to your Orion kit. Can't say about the fit. Like said, use the plastic cap. Wipe any drips and wash anything left with soap and water. Bring it to a car wash that does underside wash and be happy.
Amazon.com: Motive Products 0108 Late Model GM Compatible Power Bleeder 2-Quart Tank with Hose and Adapter : Automotive
I would think you could maybe modify an old stock cap to work as well, not really sure.
For the bottle I first just used an old Pedialite bottle with a hole in the center of the cap for the bleed tube and a very small hole off to one side to relieve the pressure. Since then I purchased a bottle from Motive and it was just the same as the one I made!
How I use the tool is to suck all of the old fluid from the MC reservoir, fill with new fluid, install the Motive and pressurize the system. Then I go to the right rear and connect a clear vinyl hose (I think 3/16 is the size and at least long enough that I can set my drain bottle on the floor while turning the bleeder screw) and bleed the inner half of the caliper, I then bleed the outer half. Since I bleed my brakes several times per track season, there is little to no change in fluid color from old to new, so I watch the bubbles passing through the drain tube and estimate their speed to judge how long it would take for new fluid to flow from the MC to the brake caliper. I follow this by bleeding the left front, left rear and finally the right front calipers. That sequence is set by the Corvette's dual diagonal brake system, where the left front and right rear are on the same half of the brake system and the right front and left rear are on the other half of the brake system.
One thing to check when using the Motive Plastic Cap is how well it will seal on your MC. Motive provides two gaskets in this kit and I found I had to use the thicker gasket. This made it very hard to turn the cap onto the MC., Once I get it started, I use a pair of Channelock pliars to turn it the rest of the way.
I usually use 2 500 ml containers of brake fluid, although if I run into difficulty with something, it may take 3. Given that AP Racing Radical R4 Brake Fluid (644 F deg dry boiling point) runs close to $50 per container with tax, I try to not waste it.
Bill
Good idea to suck the old fluid out of the reservoir, not pushing old fluid into the system.
I just take off the wheel. Place the drain pan under the wheel. Loosen the bleeder screw and let it go under control. When I feel it has had enough, tighten the bleeder screw. Move to the inner half. Move on to the next wheel. If you are lazy, leave the wheel on and hose it down immediately after the bleeding is done. After the job, I take the car to the car wash for an underbody wash and everything is cleaned. Move on to the next car and the next.
Wiping it off will damage the finish, and don't wait too long or you'll have the same discoloration of your paint.
