My corvette is throwing codes
Old Mar 27, 2025 | 07:15 PM
JoshuaDean16's Avatar
JoshuaDean16
3rd Gear
Default My corvette is throwing codes
My 2016 1le Stingray is throwing codes P0171- System too lean bank 1
P0172- System too rich bank 1
P0174- System too lean bank 2
P0175- System too rich bank 2
Its acting funny I’ve only had the car for a month and don’t know much about corvettes, which I’m trying to learn
Old Mar 27, 2025 | 08:54 PM
Kel15's Avatar
Kel15
Welcome to the forums, those are basic codes for any vehicle, Here's a simple video of one code, the others similar nature, hopefully just a plugged air filter. Let us know how you made out on the repairs .
Old Mar 27, 2025 | 09:22 PM
aklim's Avatar
aklim
Both banks? Last time I had something like that, it became a MAF. At least, that was what fixed it under warranty.
Old Mar 28, 2025 | 12:03 AM
Good luck with the repair. Hope it is something relatively simple and inexpensive.
Old Mar 28, 2025 | 05:39 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Having a stuck EVAP purge valve can set both lean and rich DTC’s especially after filling your gas tank…the intake manifold will draw in gas fumes from your EVAP canister and that will set rich codes and when all those gas fumes are burned it will then set lean codes because you basically have a vacuum leak at the intake manifold.
Old Mar 28, 2025 | 03:48 PM
bradNTx's Avatar
bradNTx
I'd clear them and see what comes back. If you get them after filling up the tank look at what C5Diag said. If they come right back clean your MAF with the appropriate cleaner. It also wouldn't hurt to check your intake for leaks after the reset.
Old Mar 28, 2025 | 05:02 PM
aklim's Avatar
aklim
You ever see that work or is it a "Hail Mary"?
I wonder if there is a way to check the MAF? Obviously it hasn't failed bad enough to throw a code but if you know what range of values to look for, maybe there is a way to see if it is reading right? Not sure.
Old Mar 28, 2025 | 05:13 PM
C5 Diag's Avatar
C5 Diag
If one has a DVOM with a frequency setting that can be used…I use a lab scope.
Old Mar 28, 2025 | 06:43 PM
aklim's Avatar
aklim
If you have a scanner, can you see MAF values? If you can see how many grams/second and have a way to see how much it should at say idle, would that work?
Old Mar 28, 2025 | 06:47 PM
C5 Diag's Avatar
C5 Diag
Yes, you check in grams/second…MAF reading should be equal to the liter displacement of the engine at “hot unloaded idle”…6.2 liters equals no less than 6.2 grams/second.
Old Mar 28, 2025 | 06:57 PM
aklim's Avatar
aklim
Is that this car or pretty much any car where I just take the displacement and that is the g/s? IOW, my 4.0L car will read 4.0g/s and my 6.2L truck will also be 6.2 g/s?
Old Mar 28, 2025 | 07:09 PM
C5 Diag's Avatar
C5 Diag
Yes, any car and should be no less than those numbers.
Old Mar 28, 2025 | 07:19 PM
C5 Diag's Avatar
C5 Diag
Great MAF sensor video by Bernie Thompson the best automotive diagnostician in the country.
To My corvette is throwing codes
