Acceleration Lag
Old May 9, 2025 | 06:06 PM
terrydennis's Avatar
terrydennis
Default Acceleration Lag
I've owned this 2016 Z06, A8 for two years and have not experienced this until today.
I was driving in about 78 degree temp on the highway at about 50 MPH, I floored it and it accelerated as usual up to about 75 MPH. I turned onto a side rode and gave it about 3/4 throttle nothing happened, there was no immediate throttle response, then it kicked in. I did this several times. I put it in manual mode and it seemed a little better, not noticeable lag. After parking the fans ran for at least 5 minutes. After 1.5 hours I checked for codes. No new codes, no stored code, no pending codes. Any Ideas? I thought it might be hot, but I've driven harder in hotter conditions with no problems. No check engine light and oil temp was in the normal range. I will drive it tomorrow and see what happens. If you have any ideas I'd appreciate them. Thanks!
Old May 9, 2025 | 06:38 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Can only offer ideas…MAF, MAP, TPS, APP, Fuel Pressure.
Old May 9, 2025 | 06:50 PM
terrydennis
Thank you for your feedback!
Old May 11, 2025 | 02:43 PM
terrydennis
Ran it hard yesterday and today. No issues. I'm glad it seems to be back to normal, but I don't trust it. Something was out of wack. Oh well, all I can do is drive it and see what happens.
To Acceleration Lag
