Shifter stuck in Reverse.
Old May 12, 2025 | 11:06 PM
vam's Avatar
vam
Default Shifter stuck in Reverse.
Battery measures 12.8v. What can cause the gear shifter to freeze in Reverse
Old May 13, 2025 | 09:36 AM
kodpkd's Avatar
kodpkd
What car is this happening on?
Old May 13, 2025 | 02:48 PM
vam's Avatar
vam
Default 2014 C7 Shifter stuck in Reverse
A friend was able to remove the console. He inserted a flat head screwdriver and pushed the solenoid to unstuck the gear shifter. Pressed the brake (brake lights came on), pushed the start button still no luck in getting the engine to start.
Old May 13, 2025 | 03:25 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Having a scan tool to see if the car is in park or neutral will help in diagnosing this no crank.
To Shifter stuck in Reverse.
