Over rev
Old Aug 17, 2025 | 05:08 PM
WildWolf's Avatar
WildWolf
Default Over rev
Is there a way to determine over revs in the Z06 like Porsche does?
Old Aug 17, 2025 | 06:24 PM
96GS#007's Avatar
96GS#007
Only parts scattered on the ground.
The fuel cutoff is a programmed number. The PCM doesn't count how many times someone bangs it.
Old Aug 18, 2025 | 10:18 AM
Blackcherry20's Avatar
Blackcherry20
I Love My C7
Old Aug 18, 2025 | 04:10 PM
rtv900's Avatar
rtv900
fuel cut off does nothing for a bad downshift in a manual
that's where the real damage is done
autos won't do an over rev downshift
Old Aug 18, 2025 | 04:54 PM
Bill Dearborn's Avatar
Bill Dearborn
Hitting 3rd when trying to shift from 4th to 5th at 6400 rpm can cause the engine to rev to about 7900 rpm. However, the sudden deceleration usually throws the driver forward before they can remove their foot from the clutch, so some of the time the rpm doesn't reach that high because the driver's foot disengages the clutch as the body is thrown forward, even with a full 6-point harness in place. There is usually some initial rear tire slippage that helps limit the rpm increase. A money shift at that speed can result in more than a damaged engine. It can mean a totaled car and/or a trip to the hospital if the car spins into an obstruction at a triple digit speed.
Bill
Old Aug 18, 2025 | 04:55 PM
96GS#007's Avatar
96GS#007
Hence my comment....parts on the ground.
Regardless, the C7 does not count the number of times someone misses a shift or bangs the limiter and that's what the OP was asking.
Old Aug 19, 2025 | 07:33 AM
Tinkertech's Avatar
Tinkertech
I believe I read once that deep down in the ECM over revs are tracked.
Mainly for warranty issues.
Old Aug 19, 2025 | 10:06 AM
rtv900's Avatar
rtv900
yeah that's why porsche does it
they won't CPO a level 3 over rev which is 500 above redline
Old Aug 19, 2025 | 03:04 PM
Damnit, Laverty's Avatar
Damnit, Laverty
They do. It’s available in GDS2. I had to track it down a few weeks ago, I got real lucky on a 4-7-4-3 shift and got the clutch in on time, but I was about to rip the valve covers off to check the springs until I figured I’d check in the tool just in case. It’s in the engine ECU section. Titled RPM Peak history or something similar.
Old Aug 24, 2025 | 04:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
This was on a C7? Which engine?
Old Aug 24, 2025 | 04:56 PM
Dano523's Avatar
Dano523
Yes, and no.
Yes part, that several of the modules (lets call them black boxes) are recording such each time that you can pull down with GM software in the case of a crash,
and you can data record on track with some after market programs on the OBDIi port with its prt device, to have that information each track event as well.
While no, since no simple button push(s) to get that feed back/count easily for end user instead.
Old Aug 24, 2025 | 05:00 PM
Damnit, Laverty
c7 Z51, 6.2.
I’ll plug it in tonight and get pics.
Old Aug 24, 2025 | 06:51 PM
96GS#007's Avatar
96GS#007
c7 Z51, 6.2.
I'll be interested to see what this looks like since there's the "oh ****, missed a shift" and then there's "banged the rev limiter" trying to grab that last mph. In particular is there any differentiation between the two.
Old Aug 24, 2025 | 11:20 PM
Damnit, Laverty
it doesn’t show banged the limiter, it shows oh **** I put a window in it.
Old Aug 24, 2025 | 11:36 PM
Damnit, Laverty
It’s under [K20] Engine Control Module, Event Information, Engine Overspeed Event Data (right next to Oil Level Warning Data btw).
here’s what it reports.
To Over rev
