Issues with Range on C7
Old Oct 7, 2025 | 08:31 PM
paulr3579@yahoo.com's Avatar
paulr3579@yahoo.com
Default Issues with Range on C7
I bought the Range module to keep my 2016 C7 from switching from 4-cylinder to 8-cylinder mode and back. When driving at lower speeds as in on neighborhood roads at 35-45 MPH I feel a strange shuddering in the car. Wondering if it's still trying to switch modes or maybe it's something else. Anyone else have this problem?
Old Oct 8, 2025 | 05:53 AM
Markmbaha1's Avatar
Markmbaha1
Follow, that area is 90% of my driving.
Old Oct 8, 2025 | 08:32 AM
Tinkertech's Avatar
Tinkertech
Sounds like you need the triple flush for the transmission, Mobil1 Blue label.
The 'flush' really isn't for the transmission but for the torque converter's clutches that are 'grabbing' when the original ATF fluid absorbs moisture.
Old Oct 8, 2025 | 09:45 AM
kodpkd's Avatar
kodpkd
I used a range type device on my 2014 without any issue. It just stopped the V4 mode, nothing else.
Old Oct 8, 2025 | 10:28 AM
paulr3579@yahoo.com
I didn't notice the shuddering before I installed the Range. But maybe it was there and I hadn't drive the car long enough to notice.
Old Oct 8, 2025 | 10:29 AM
paulr3579@yahoo.com
How can you tell if the V4 mode has been stopped?
Old Oct 8, 2025 | 10:34 AM
kodpkd's Avatar
kodpkd
There is a V4 V8 indication on the forward instrument fuel range mode display. If you want to check if the Range is making the shudder, just remove it and drive the exact same way and see if it changes.
Old Oct 9, 2025 | 03:32 PM
Rikstoy2019's Avatar
Rikstoy2019
Cruising
I haave used Range for 6 years and no problems like you are describing.
To Issues with Range on C7
