P0300 Misc misfire - rough idle - bogging
Old Nov 3, 2025 | 07:34 AM
bdeis61159's Avatar
bdeis61159
Default P0300 Misc misfire - rough idle - bogging
Received this code back in June. It went away and came back. I reset it and has NOT come back. I did add a can of fuel line cleaner. Now, it seems to idle mildly rough, almost unnoticeable and occasionally will bog down after running 70 mph for a couple hours. It only lasts about 5 seconds and returns to normal.. any suggestions? Mass air flow? Gas filter? ( I hope not). Thanks in advance.
Old Nov 3, 2025 | 08:03 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Can be just about anything so instead of wasting your time and money find an automotive diagnostician (not mechanic) who will diagnose it quickly and accurately with the right equipment.
Old Nov 6, 2025 | 08:28 AM
Tinkertech's Avatar
Tinkertech
If you don't have the proper test equipment, you're just firing the parts cannon at your problem.
If you lack the equipment and knowledge, then find a professional automotive diagnostician.
I give a dealership a 20% chance of fixing it the first time with replacing only the part that is causing your problem.
Old Nov 6, 2025 | 11:46 PM
Chip E.'s Avatar
Chip E.
St. Jude Donor '16
Default Misc misfires
p0300 is miscellaneous misfire…essentially The computer is saying, “Dude, there’s been a lot of misfires in more than one cylinder”.
I suggest locating some with a more sophisticated OBD2 scan tool. They’ll be able to pull the misfire history. Cylinders 1,4,6,7 are your DOD/AFM cylinders. If it’s one or more of those cylinders consistently misfiring, it’s most likely a stuck lifter. If it’s any of the other cylinders, it could be a spark plug, spark plug wire, injector or ignition coil.
Please let us know what you find.
To P0300 Misc misfire - rough idle - bogging
