Fuel system cleaner
Old Mar 18, 2026 | 09:57 PM
Rwp315's Avatar
Rwp315
Default Fuel system cleaner
Reading some of the indication issues, is there such a specific fuel system cleaner/process that is recommended?
Have a ‘15 Z51 with 4,800 miles and if possible prevent any issues.
Old Mar 18, 2026 | 10:28 PM
NortonCO's Avatar
NortonCO
You will likely get many different opinions on this.
That said, Top Tier gas helps keep the fuel system clean with every fillup. In the additive world, Techron is the goto for many.
Old Mar 18, 2026 | 10:32 PM
Rwp315's Avatar
Rwp315
Do you use Techron every fill up or every so often?
thanks
Old Mar 18, 2026 | 10:39 PM
Rwp315's Avatar
Rwp315
Just read the specifics on Techron and it says no more than (2) per oil change.
Old Mar 18, 2026 | 10:41 PM
NortonCO's Avatar
NortonCO
I run Top Tier gas, which includes cleaners that function similarly to Techron on a continual basis, but I still have a habit of adding a bottle when I change the oil.
Old Mar 18, 2026 | 10:45 PM
Rwp315's Avatar
Rwp315
👍, just noticed your Norton. A lot of laughs!😂😂
Old Mar 19, 2026 | 09:27 AM
kodpkd's Avatar
kodpkd
I use a bit of Techron at every fill, because I don't fill at a Top Tier station.
Old Mar 19, 2026 | 09:45 AM
1Hotrodz's Avatar
1Hotrodz
Techron, one 12 Oz. bottle, every 2000 mi. with a fuel fill up. Also I believe "Chevron" fuel has Techron blended in it. Not sure if you have that gas station near you. If not, always use a top tier fuel, especially with Direct injected engines. The detergent additives help clean the injectors.
Old Mar 19, 2026 | 04:27 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
GM has a "Fuel Treatment Plus" or something like that. At one time it was apparently just Techron, the plastic bottle had a molded-in log on the bottom from Chevron.
The current GM stuff now has a bottle with no Chevron markings so it may still be Techron or something else.
Old Mar 19, 2026 | 04:32 PM
Gearhead Jim
St. Jude Donor '13
There are stories about engines failing if too much Techron was used, but I don't know the specifics or what "too much" is.
I add a bottle of the GM treatment once every Spring (5k-15k miles per year) with no regard to when the next oil change will be, I get an oil analysis at each change and the Techron seems to have no negative effect on the analysis results.
Old Mar 19, 2026 | 04:48 PM
Laguna Blu's Avatar
Laguna Blu
One 20oz bottle of Techron at every oil change.
Old Mar 19, 2026 | 05:35 PM
Pettrix's Avatar
Pettrix
Techron is the first and the best. GM used & licensed Techron formula for their fuel system cleaners. PEA-based formula
Old Mar 19, 2026 | 05:44 PM
Rwp315's Avatar
Rwp315
thanks
Old Mar 19, 2026 | 09:23 PM
MissileDoc's Avatar
MissileDoc
This is what I do also.
Old Mar 19, 2026 | 09:38 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Techron and Sunoco Ultra94 fits my needs just fine!
Old Mar 19, 2026 | 09:51 PM
Rwp315's Avatar
Rwp315
Appreciate all the responses.
Old Mar 20, 2026 | 08:14 AM
Tinkertech's Avatar
Tinkertech
Every time you use Techron a little of the cleaner can work is way past the rings and into the oil. Using it too often can dilute the oil. Kind of like the issue Honda has on their 1.5L turbo, oil dilution from fuel getting past the rings and into the oil.
I believe the optimum time to use Techron would be on the last tankful of gas, after it's about empty then change the oil.
Of course, if you're having problems, such as a fuel level sending unit, then I'd use it anytime as much as needed until the issue is cleared up then change the oil. long term storage is also acceptable. (can't get into the oil, its all in the tank(.
I just would not leave a high percentage of Techron in the oil any longer than needed. ie: adding a bottle every month.
To Fuel system cleaner
Old Mar 20, 2026 | 08:38 AM
CraigStu's Avatar
CraigStu
Tinkertech for the win. I worked for BMW North America in the early 80s when all cars were having trouble w/ carbon buildup on the intake valves. BMW did a bunch of Techron testing by having their service and sales reps use it in their company cars. Each rep was assigned a schedule of how often to use the Techron. I sure don't remember any #s from then but I definitely remember that they blew up several engines. The cause was diluted engine oil. Think about a chemical that can clean off baked on carbon and ask yourself what it would do the engine bearings etc. As Tinkertech says, I would use it as recommended on the bottle and then change the oil.
Old Mar 20, 2026 | 01:48 PM
Pettrix's Avatar
Pettrix
The Honda 1.5 Turbo issue is due to the Direct Injection design and the poor programming Honda did when the engine was in a cold weather climate. It went overly rich and would overwhelm the cylinders with fuel and then wash down into the crankcase. Honda did a reprogram on the fuel delivery when cold and recommended a longer drive when cold to help burn off the fuel in the crankcase.
That Honda 1.5L turbo is not a good engine design. Blown head gaskets are another issue due to the cheap small cylinder head bolts used by Honda and the crappy head gaskets. Add a turbo that increases cylinder pressure = blown head gasket.
If used as directed, the Techron fuel system cleaner will not harm anything. When overly used, yes, it can cause issues.
Old Mar 21, 2026 | 01:45 PM
Gearhead Jim
St. Jude Donor '13
Continuing off topic:
My wife's 2020 Honda CRV has the oil dilution problem, I saw it on the first oil change/analysis. The local Honda dealer said there was nothing they could do to reduce the problem, but I would be ok using 0W-30 oil instead of the specified 0W-20. Analysis shows our Mobil-1 0W-30 when drained has a viscosity at the upper end of the 0W-20 range. I found some info indicating that the same engine in England is recommended to use 0W-30 or 5W-30 (can't remember which), so that suggests it's all about meeting the US CAFE fuel economy standards and don't worry about the engine if it lasts through the warranty period.
