Horn fuse
Old Mar 22, 2026 | 04:49 PM
red-vette-ragtop's Avatar
red-vette-ragtop
Default Horn fuse
The horn fuse blew when I was using it. Replaced it. An hour later it blew again. Any ideas as to why?
Old Mar 22, 2026 | 05:52 PM
kodpkd's Avatar
kodpkd
Not that hard to remove and check it out.
Old Mar 22, 2026 | 05:58 PM
red-vette-ragtop
Originally Posted by kodpkd;[url=tel:1609525157
1609525157[/url]]Not that hard to remove and check it out.
https://www.youtube.com/watch?v=szeCC9ujgS8&t=37s
Not sure how that video relates to my problem. Can you elucidate a little bit, please? I’m talking about the 15 amp fuse in the fuse box on the passenger side under the hood. It blew. I replaced it. It blew again. I want to know what’s causing this. I don’t need to know how to remove the air bag or horn from the steering wheel. I might be missing your point though, if you could give more explanation, I would appreciate it, thanks.
Old Mar 22, 2026 | 08:09 PM
kodpkd's Avatar
kodpkd
Never mind. I am sure it isn't in any of the horn connections. Just keep replacing the fuse until it starts to work.
Maybe check the horn relay,,,, KR3
Old Mar 22, 2026 | 08:53 PM
red-vette-ragtop
Originally Posted by kodpkd;[url=tel:1609525438
1609525438]Never mind. I am sure it isn't in any of the horn connections. Just keep replacing the fuse until it starts to work.
Ah, so you’re saying it could be a short in the horn assembly. Wasn’t that clear in your original post. OK, I’ll check that out, sounds like a good point, thanks.
Old Mar 22, 2026 | 10:12 PM
kodpkd's Avatar
kodpkd
Thank you. Sorry for being short.
Old Mar 22, 2026 | 11:24 PM
red-vette-ragtop
Originally Posted by kodpkd;[url=tel:1609525689
1609525689[/url]]Thank you. Sorry for being short.
No worries! Thanks!
Old Mar 23, 2026 | 02:43 PM
Moved to C7 Tech.
Old Mar 23, 2026 | 11:05 PM
red-vette-ragtop
UPDATE: I checked and everything looks good, no exposed wires, no bad bends or kinks. Made sure the plug was seated good. Bumped the horn 4 times, so far so good. I don't know—I hope just messing around with it fixes it. We'll see.
Old Mar 24, 2026 | 09:36 AM
kodpkd's Avatar
kodpkd
Great. I have done the same thing. Messing with things sometimes fixes them. BEEP BEEP
I was going to ask if it was the correct 15 amp fuse.
Let us know how it goes.
The other thing to check. Remove the left wheel well liner and see if the wires connecting to the horns are good.
If it still honks I found this.
Horn relay.
Unlike many older vehicles where the relay is a standalone, swappable component, the horn relay on the C7 Corvette is built directly into the Underhood Electrical Center (fuse box). This design choice means:
  • Integrated Component: The relay is a non-serviceable internal part of the circuit board within the fuse box.
  • GEEEEEZ!
This is where the horns are located.
To Horn fuse
