C7R Engine Builder?
People can be strange...after my post with the link, a poster agreed with a previous poster that Pratt and Miller build the engine. I guess some people just doubt the truth even in the face of irrefutable evidence...I have a friend who refuses to believe we went to the moon.
Everybody has their insanity, I enjoy mine and wish the same for everybody else.
Satisfied?
Satisfied?
It's crazy the same thing has to be stated three times now before it sinks in...
C7.R engine
4.09 bore
3.185 stroke
LS7 engine
4.125 bore
4.00 stroke
LS3 engine
4.065 bore
3.622 stroke
LT1 engine
4.06 bore
3.62 stroke
Then there's a link in this subject that says that the LS5.5R engine is based on the LS7 engine
C7.R engine
4.09 bore
3.185 stroke
LS7 engine
4.125 bore
4.00 stroke
LS3 engine
4.065 bore
3.622 stroke
LT1 engine
4.06 bore
3.62 stroke
It is a big job but weight reduction is the benefit. Also, the anti-lock brakes would be replaced with a race-part master cylinder with bias bar adjustment. The electronic limited-slip would be replaced with an adjustable race-part mechanical limited-slip. And so on. The rev-match manual transmission could probably just be unplugged or else replaced.
The LS7 crate engine has 505 HP. It has very good internals but does have cast pistons. GM also has a Gen 5 LT1 crate engine not yet released. So then the engine controller for the LT1 crate engine might be used on the C7 for the purpose of removing all the C7 OEM electronics and street equipment
I believe the Gen V engines(LT1) have a different motor mount location
from the Gen IV engines(LS7,etc), thus they are not a direct drop in into the C7 chassis.
If you are going to that much trouble to fit a LS7 into the C7, why not sleeve the LT1 that came with the car to a 4.125" bore and install a 4" crank with new rods and forged pistons, and ported heads, etc. It would give you the 427 cu in displacement yet have stronger components.
http://forums.corvetteforum.com/c7-t...-corvette.html
http://www.jegs.com/p/Chevrolet-Perf...03674/10002/-1
But when the LT1 crate engine comes out then a simple engine controller will be available for the LT1. But yeah, when the LT1 engine controller is available, I would think about an LT1 instead of adding motor mount brackets to the C7.
And most of the GMPP crate engines are not just replacement engines but also engines for street-rod builds but that makes the street-rod electronics available for those who already have the engine:
http://gmauthority.com/blog/2013/11/...ngine-concept/
Well, don't misunderstand a race car build. All the OEM wiring, fuse boxes, and junction boxes are pulled off the car. Then the car is just re-wired as a race car build. The seat motors come out, the airbags come out, the dash comes out, and all street equipment is pulled off the car. The anti-lock brake parts are pulled off the car and a master cylinder with bias bar adjustment is used. The electronic limited-slip is replaced with an adjustable mechanical limited slip. The simple engine controller electronics of the crate engines allows the street equipment to be pulled off and of course one engine that is available is the LS7. Finally, a race car build pulls 500 to 800 pounds weight off the car and then adds the weight of a roll cage back
package that improves the C7's handling.
I don't misunderstand a race car build and the reduction of weight of the race car, but that has nothing to do with the decision of which engine you are going to use; a 427 cu in LS7 or a 427 cu in LT1.
A race car could have an electronic limited-slip but the purpose would be easier adjustment and there would need to be a computer to run it. The OEM electronics are too elaborate and tied into too much street equipment to use on a race car.
Similarly, race cars usually don't have electronics running an anti-lock braking system. More often they have a master cylinder with a bias bar adjustment.
(Certainly, Formula 1 has everything but they are not using OEM parts.)
Finally, take a look at the fuel-injected GMPP crate engines and several of them include an engine controller electronics that only controls fuel injection and ignition. There are no electronics for limited-slip and anti-lock brakes. (I suppose that the crate engine electronics are still expecting a cat between oxygen sensors.)
The race car might have OEM electronics with complete and total re-programming but that would be unusual.
Here are two links to the Viper Competition Coupe:
http://www.caranddriver.com/reviews/...specialty-file
http://www.allpar.com/cars/viper/competition-coupe.html
That's 3190 pounds weight including roll cage. That's fairly heavy but probably due to the SCCA World Challenge rules. And it's just some photos of a production car built into a race car.
I'll go to the Corvette Racing website and look for interior photos and under-the-hood photos
I'm replacing electronic limited-slip, taking off anti-lock brakes, taking off AFM, pulling out the entire dash, taking out airbags, and so on.
Don't replace engine or build engine either one. Just replace the engine electronics and then the shop-built price of the track car drops by twenty-thousand
http://hpd.honda.com/%5Ccontent%5Cme...ura_TLX_GT.pdf
Also, check out the electronics for the car !
Here is a link about the C6.R as compared to an OEM car:
http://gmauthority.com/blog/gm/chevr...rvette-racing/
The brakes are different and the transaxle is different. Electronics would be interesting.
See, the OEM anti-lock brake system is not adjustable. A racing master cylinder is adjustable with a bias bar.
Also, the anti-lock brake system is included in the stability control systems and so there's a lot of electronics involved. Race cars don't usually have stability control systems unless it's some high-end system for pulling 3 to 5 G's
I have seen a brake bias adjuster added to a factory ABS system, though, and it seemed to work fine.
