Top speed!!!
Old Jan 29, 2014 | 08:59 PM
96ss#80's Avatar
96ss#80
Default Top speed!!!
Does anyone know the estimated or actual top speed of the new Z06 yet?
Old Jan 29, 2014 | 09:02 PM
LT1xL82's Avatar
LT1xL82
I have read speculation it could top 200 mph. Yikes!
Old Jan 29, 2014 | 09:19 PM
Blackdevil77's Avatar
Blackdevil77
I'm sure it's over 200. The speedo in the base Vette goes to 200mph, and they changed it to 220mph. No reason to change it unless it can top 200mph, so I'm sure they fully expect it to.
Old Jan 29, 2014 | 09:35 PM
AGFNTB's Avatar
AGFNTB
Solve for v
Old Jan 29, 2014 | 09:49 PM
Zach495's Avatar
Zach495
I thought I read somewhere that it wont be as fast as the C6's, as the goal was to be better on the track, not a 1/4 or top speed.
Old Jan 29, 2014 | 11:24 PM
96ss#80's Avatar
96ss#80
Im sure it will be at least 200mph also. The C6 ZR1 did 200mph. Does anyone know the coefficient of drag on the C7 Z06 vs the C6 ZR1?
Old Jan 29, 2014 | 11:29 PM
vant's Avatar
vant
Old Jan 29, 2014 | 11:43 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
The C6 ZR1 has a VERY impressive top speed rating of 205 mph, it will be real interesting to see if the C7 Z07 tops that. Although I think the C7 Z06 will edge out the C6 ZR1 in just about all the performance categories, I personally don't think it will beat the C6 ZR1's 205 top end speed, primarily b/c of all the downforce the C7 Z06 has which kills top end speed and b/c it probably will be heavier than a C6 ZR1 and make about the same HP.
Old Jan 30, 2014 | 10:06 AM
stevebz06's Avatar
stevebz06
I bet even fewer owners have hit top speed in their cars than have tracked their cars.
Old Jan 30, 2014 | 11:05 AM
Mopar Jimmy
St. Jude Donor '06
100% But a small percentage of guys gets hung up on top speed as a bragging right thing (a close friend of mine is one of them).
Old Jan 30, 2014 | 11:51 AM
FNBADAZ06's Avatar
FNBADAZ06
I'd guess by the time power and weight numbers are finalized, the base C7 Z06 will match, or exceed, the ZR1's top speed...but not the Z07 package with the extra aero. Downforce and drag created by the Z07's agressive aero will impose a penalty there.
With a closer gear ratio in the first 6 gears of the auto car, which may give it a better overall final drive ratio in every gear, I'd guess the C7 would win any time to speed races. Once aero drag kicks in, whoever has the superior drag-to HP ratio (both cars MAY have equivalent final HP figures at the same general RPM and effective final drive ratio), is going to win the top speed race...given enough room to reach Vmax. A C7 Z06 might get to Vmax sooner, but a C6 ZR1 might have the higher Vmax number.
It's all speculation until the final specs are given for the C7 Z06.
Old Jan 30, 2014 | 11:59 AM
ChucksZ06's Avatar
ChucksZ06
I would guess 210 with as little downforce as possible dialed in.
Old Jan 30, 2014 | 12:30 PM
axr6's Avatar
axr6
I remember, living in Europe, top speed was pretty much the most popular performance indicator. Kind of understandable, particularly in Germany, where one could legally reach tops speeds on the Autobahn.
Old Jan 30, 2014 | 12:47 PM
mirage2991's Avatar
mirage2991
GM said the CoD will be about the same as the ZR1, which means top speed should be on par with the ZR1. With the car being heavier it will only take more distance/time to get there since the hp/tq are similar. Wouldn't be surprised to see it go 203-205...question is will GM have it certified like the ZR1?
The ZR1 certified at 205, but it's reccorded top speed during one of the 5 (It hink it was 5) runs was 207.xx, if memory serves me right.
and for those thinking the base can go 200 just because the speedo says 220, LOL...
Old Jan 30, 2014 | 03:20 PM
quick04Z06's Avatar
quick04Z06
199.999997 mph, governor limited. Tadge says so. Well, no, not really....
Old Jan 30, 2014 | 05:18 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
I will say 207!
Old Jan 30, 2014 | 05:37 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I doubt anyone does since the car is still under development, but...
-Similar Frontal Area to the ZR-1
-Similar Drag to the ZR-1
-Similar HP to the ZR-1
All points to a very similar top speed to the ZR-1. Probably -5>Vmax>1MPH.
To Top speed!!!
Old Jan 30, 2014 | 05:52 PM
JoesC5's Avatar
JoesC5
ZR1 is .35(C6 Z06 without the Z07 is .34)
Tadge said the C7 Z06 would be between .35 and .37. I'm assuming that he mean the base Z06(with the small front splitter and the Z51 rear spoiler) would be .35 and the level three Z07 with the more aggressive aero aids to increase down force, will be .37.
Old Jan 30, 2014 | 07:35 PM
ChucksZ06's Avatar
ChucksZ06
The weight of the car has very little to do with the top speed...it is all about the aero drag and pushing the car through it.
Old Jan 30, 2014 | 09:09 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
The top speed of the ACR Viper SRT10 is around 180-185mph with all that 1100 lbs of downforce... I've even read articles where they had a hard time breaking 175mph..
Check out this post..... http://forums.corvetteforum.com/othe...onneville.html
Isnt the C7Z offering around 750 lbs of downforce? If thats the fact then it'll have a hard time breaking 200mph... maybe even 190mph.
