Ring Time pool
Old Sep 17, 2014 | 08:43 AM
racezx9's Avatar
racezx9
Default Ring Time pool
I figure to pass the time I start this pool here on the ring time for the new Z06.
I say the new ring time will be 7:10 due to the new Aero, traction management and 8 speed transmission. beating the old Zr1 record by 9 second.
anyone else care to put up some time.
Old Sep 17, 2014 | 11:44 AM
Flyboy22's Avatar
Flyboy22
I bet 7:07, but I'm calling that they use the manual to do it. I don't think they have the cooling sorted on the auto yet. Downforce and the wide band torque will make the difference.
Old Sep 17, 2014 | 11:47 AM
Stingray23's Avatar
Stingray23
I'm gonna say 7:XX. J/K. 7:13
Old Sep 17, 2014 | 11:48 AM
dwward's Avatar
dwward
Jukebox Graduate
Old Sep 17, 2014 | 11:55 AM
ChevyChad's Avatar
ChevyChad
one dollar
Old Sep 17, 2014 | 12:08 PM
Stingray23's Avatar
Stingray23
Originally Posted by ChevyChad
one dollar
lol
Old Sep 17, 2014 | 12:33 PM
DRLC5's Avatar
DRLC5
Alraedy started.
https://www.corvetteforum.com/forums...ring-time.html
Old Sep 17, 2014 | 04:23 PM
johnglenntwo's Avatar
johnglenntwo
Default <7:08.69 Nissan GT-R Nismo (2015)
Win!!!
Old Sep 17, 2014 | 07:48 PM
JMB's Avatar
JMB
Active Streak: 90 Days
Sorry to disappoint you but GM won't run the 'Ring until the auto is ready....the 8 speed auto will spank the 7 speed manual! If you have any doubt, just look at the CTS-V times!
Old Sep 17, 2014 | 09:30 PM
ChevyChad's Avatar
ChevyChad
Originally Posted by Stingray23
lol
glad someone at least understood the humor
Old Sep 17, 2014 | 09:38 PM
SBC_and_a_stick's Avatar
SBC_and_a_stick
Not if it overheats. Correction, no because it will overheat.
The ring is 13 miles, equivalent to 5 laps at a normal racetrack. That's about the limit for the Stingray, and the Z06 will have more weight and torque to deal with. Mero would also drive it much harder than 99.99% of the guys who do HPDEs.
Old Sep 17, 2014 | 09:54 PM
thebishman's Avatar
thebishman
Wrong. The 'Ring has some very long straights which will markedly cool down the components and allow the car to run in a higher gear, hence lower revs, hence lower oil temps. Now you may well be correct on much shorter, tighter tracks. Hence the need for the additional tranny cooler.
Bish
Old Sep 17, 2014 | 09:59 PM
SBC_and_a_stick
Bish
I wouldn't be so sure of that. The transmission is getting consistent pounding on the straights. More air? Yes. But also way more thrust as well.
Chris Harris had a nice video with one of the Porsche engineers. He said the toughest part to design is the transmission, particularly keeping it together on high speed portions of the track. It stays in one gear and heats up. You can't distribute the load on more than one gear sets.
Old Sep 18, 2014 | 01:16 AM
U2Slow's Avatar
U2Slow
Old Sep 18, 2014 | 12:48 PM
johnglenntwo
Default Redemption!
Originally Posted by Halltech
6.98
Yes, we could cut'um some slack on the ignition problems too!
Old Sep 18, 2014 | 01:09 PM
JoesC5's Avatar
JoesC5
I agree. When I ran at Talladega, my coolant and engine oil temps would jump to 212/205 when I would run 160+ on the back stretch and would start to drop when I slowed down on the front stretch with no throttle application. Running WOT, even for a short distance, ~3500' on the back stretch cause the temps to rise even though I was forcing a lot of air through the radiator and the separate liquid/air heat exchanger for the oiling system from 145 to 160+ MPH.
The temps for the transmission and rear axle would also see the same rise in temps at high speeds at WOT.
Old Sep 18, 2014 | 01:41 PM
thebishman's Avatar
thebishman
When manufacturers run a car at the 'Ring to generate a time, its not like they're doing multiple laps and building up heat like we see at HPDE events. Manufacturers might run one lap to get everything up to operating temps at 8/10s; or perhaps they just keep the tyres warm in the pits, have the fluids warm in the car and then just go for it in one lap; not multiple. Hence the assumption that this car will overheat the A8 in one lap of the 'Ring is pushing it IMHO.
To Ring Time pool
Old Sep 18, 2014 | 05:20 PM
johnglenntwo
Default Good Point!
I'm sorry, I thought we were talking about the 2017 Zora platform with 3.85lbs/hp and has 6 electron body panels, and maybe 6 electron wheels.
What would be the point of making that if the Z07 did the deed!
Oh well he Z07 is screwed!
Old Sep 19, 2014 | 02:43 PM
johnglenntwo
Default Actually!?
6.98
I don't think anyone would complain if a Tuner Sponsored C7 made an aftermarket Ring run!
You know just for Giggles!
Old Sep 19, 2014 | 03:56 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
It will be interesting to see if GM runs the A8 or M7 around the ring. I suspect the A8. I was joking about the Zora. No way to know what it will run, unless they have one there already. The C7 Z07 will run 6.59.
I would love to sell our ULZ700 to someone in Germany that would set it up to run the Ring. With 3.9lbs/hp and PSC2s who knows what it might do. I know the Johnny O'Connell said "Oh my God, this is the fastest Corvette I have ever driven. This is faster than my racecar!" Was he saying that to smooth my ego? It could be, but he then stated, Jim, I have driven a lot of cars, and everyone thinks there's is something special, but this one is simply unbelievable".
It would be so cool to have someone like Johnny or Andy drive the C7Z06 at the Ring. I realize that it has more weight/hp than the ZR1,
