Rate this car
Old Nov 28, 2014 | 07:40 PM
CHCChris's Avatar
CHCChris
Default Rate this car
Hi Guys
This car arrives at my local dealership soon and I have the opportunity to buy it. Is it missing anything critical (or cool?).
SDCVHQ
Model Year: 2015 Event Code: 3300-Order Scheduled for
Production
Make: Chevrolet Order #: SDCVHQ
Model: Corvette MSRP: N/A
1YZ07-Stingray Coupe, Z06
PEG: 3LZ-Package: 3LZ Order Type: TRE-Retail Stock
Primary Color: GBA-Black Stock #: N/A
Trim: 196-Trim, Suede, Jet Black Inventory Status: Available
Engine: LT4-Engine, Gas, 8 Cylinders Total Cash Allowance: Not Available
Transmission: MEK-Transmission, Manual, 7 Speed
Additional Vehicle Information
Vehicle Options
All Options
196-Trim, Suede, Jet Black 3LZ-Package: 3LZ
AAB-Memory Package AE4-Seat, Competition Sport Bucket
AG2-Adjuster: Seat, Pass, Multi-Directional AJK-Seat Adjuster, Power Bolster and Power Lumbar
B4Z-Performance Traction Management CFA-Roof panel, Body Color, Carbon Fiber,Removable
CJ2-Air Conditioning D42-Cargo Net and Luggage Shade
DD0-Mirrors, O/S heated, power, LH auto dimming
DD8-Mirror, I/S R/V Auto Dimming
EYT-Ornamentation Ext Emblem Nameplate Carbon Flash Pkg
FAY-Trim Interior, Carbon Fiber
FE6-Suspension, Handling and Performance GBA-Black
GU6-Rear Axle, 3.42 ratio, Limited Slip IO6-Infotainment, Connectivity and Navigation
IWE-Suede-Wrapped Upper Interior TrimPackage
J56-Brake System, Power, Frt; Rear Disc,Antilock
J6F-Caliper: Red KQV-Seats, Heated and Cooled
LT4-Engine, Gas, 8 Cylinders MEK-Transmission, Manual, 7 Speed
N26-Steering Wheel, 3-Spoke, Suede
N38-Steering Column Tilt,Telescoping, Power
NPP-Exhaust: Dual Mode, Performance Q6J-Wheel 19x10 Frt, 20x12 RR, Aluminum,Comp. Gray Paint
UHS-Driver Information Center UQS-Audio System Feature, Bose Premium 10-Speaker
UQT-Performance Data & Video recorder VK3-License Plate Bracket, Front
VV4-Internet Connectivity, Mobile XFK-Tires, P285/30ZR19-P335/25ZR20, BW
Old Nov 28, 2014 | 08:03 PM
OH THREE Z's Avatar
OH THREE Z
2018 C4 of Year Finalist
Originally Posted by CHCChris
Hi Guys
SDCVHQ
Production
Vehicle Options
All Options
This is a stage 1 aero car.... If that matters to you the aero pieces will be available aftermarket very soon
Also, before you commit to this car you should make sure the Competition Seats are comfortable to your body type
Seems like there will be an inventory of M7 cars. I wouldn't settle for anything less than exactly the car you want
Hope it work out for you
Old Nov 28, 2014 | 08:14 PM
Glenn Quagmire's Avatar
Glenn Quagmire
What makes you say that this is a stage 1 car?
Old Nov 28, 2014 | 08:26 PM
OH THREE Z's Avatar
OH THREE Z
No CFZ
Old Nov 28, 2014 | 10:15 PM
C2Jeff's Avatar
C2Jeff
Do you really want the Z07 package? It's pretty extreme for a daily driver but very potent as a track car. I'm told it won't be as comfortable a ride as with a non-Z07 car. If you're planning to track the car a lot, then it sounds amazing. The Stage 2 & 3 Aero packages are on constraint so if you really want one of them, you're going to have to wait a bit, so I'm told.
Old Nov 28, 2014 | 10:19 PM
Glenn Quagmire
No CFZ
Actually, the 1YZ07 designates this as a Z07 (which means it's a stage 3). The CFZ/CFV only designates the finish of the aero parts, and doesn't have anything to do with which stage it is.
Old Nov 28, 2014 | 10:33 PM
charliebrown266's Avatar
charliebrown266
i may be wrong but i thought 1YZ07 just code for Z06! it would have CFZ/CFV on if it was a Z07
Old Nov 28, 2014 | 10:34 PM
Dmenace's Avatar
Dmenace
1yz07 means coupe
Old Nov 28, 2014 | 10:35 PM
rob3's Avatar
rob3
Oh Three Z is correct, this a a stage one car. The 1YZ07 code is the code for all of the new Z06 Coupes (regardless of aero package, or other options). The convertible Z06 is 1YZ67. The CFZ/CFV designates finish of the stage 2/ stage 3 components, but you need to have one or the other code on the car for it to be a stage two or higher -- the Z or V indicates the type of finish (Z = Carbon Flash and V = visible carbon fiber).
As for the comp seats, whoever said you should try to sit in them before buying the car, gave you good advice. I really like the way they look, but then sat in one and sat in the GT seat, and ended up opting for the GT seat. I could live with the comp seat, and if the car was going to see a lot of track time would have gotten it, but the GT seat was more comfortable.
Good luck with your decision.
Old Nov 28, 2014 | 10:37 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
Correct.
S.
Old Nov 28, 2014 | 10:55 PM
rob3's Avatar
rob3
Originally Posted by Snorman
Correct.
S.
That is correct. It would have CFZ or CFV of it was either a stage 2 non-Z07 or Stage 3 Z07. The code for the stage 3 Z07 package is . . . . "Z07".
It would have been at the bottom of the order sheet after the VV4.
Old Nov 28, 2014 | 11:12 PM
Glenn Quagmire
Sorry...I stand corrected. Although, intetestingly, I went back and looked at the Workbench doc from the dealer, and the version from NCM...and some of the nomenclature is different.
Old Nov 29, 2014 | 07:14 AM
CaryBob's Avatar
CaryBob
Hi Guys
You have the highest trim level (3LZ at $8,650) and few other options. The only other options are Competition Seats with suede inserts and wheel ($2,495)and the carbon-fiber dash trim ($995). Total MSRP is $91,135.
Oddly, your listing does not include any wheels. I assume the order does not include any of the extra-cost wheel options.
As several people have pointed out, your car does not include any of the extra-cost aero options, some of which will eventually be available in the aftermarket, and it is not the super-duper track-focused version (Z07 option). But it is otherwise very nicely configured, particularly from a comfort and convenience point of view. If you are OK with a black-on-black car it sounds pretty good to me.
Old Nov 29, 2014 | 07:23 AM
racezx9's Avatar
racezx9
I see the comp gray painted wheels in there.
Old Nov 29, 2014 | 10:52 AM
CaryBob's Avatar
CaryBob
You're right! Adds $595 to price tag.
Old Nov 29, 2014 | 11:02 AM
BOBSZ06's Avatar
BOBSZ06
Pretty much the same as my car:
I went with the Q6U, Black wheels for the Triple Black look.
I also did not get the suede on the comp seats.
AND I will be getting the A8.
Other than that, that is my order!
The crystal red highlights will be added to my CFZ (aftermarket purchase), and the calipers will be painted CR as well.
Very masculine, aggressive looking car, GREAT CHOICE!!!
Old Nov 29, 2014 | 11:14 AM
CHCChris's Avatar
CHCChris
Wow, thank you for the discussion! I feel way more comfortable with the specs of this vehicle.
Now on to the price.... they are asking for a 15k markup and that is after getting them down from originally asking 25k. I don't really care too much about paying a mark up, but don't want to pay for one if the demand isn't there to command one. Thoughts on this?
Edit: By the way they are unable to tell me what this car will sticker for just that it will be marked up 15k.
To Rate this car
Old Nov 29, 2014 | 11:28 AM
BOBSZ06's Avatar
BOBSZ06
Now on to the price.... they are asking for a 15k markup and that is after getting them down from originally asking for 25k. I don't really care too much about paying a mark up, but don't want to pay for one if the demand isn't there to command one. Thoughts on this?
Check the Black cars at Kerbeck that you can buy now for MSRP... not $15k over!!
NEVER PAY OVER MSRP...NEVER
They have several that are not spoken for with the M7.
The order may be able to be changed to a local dealer via courtesy delivery OR just have Kerbeck ship it to you.
https://www.corvetteforum.com/forums...available.html
Old Nov 29, 2014 | 11:33 AM
CHCChris's Avatar
CHCChris
Originally Posted by [B
NEVER PAY OVER MSRP...NEVER[/B]
Awesome, thank you. I will take a look at Kerbeck. Will they cover the shipping cost?
Old Nov 29, 2014 | 11:36 AM
Glenn Quagmire
Your theme is going to look awesome...can't wait to see pics!
