Jacking points Z06
The only thing I can find on the manual that refers to jacking points other than the frame ones on the sides are these, but you probably already know this.
I have a scissor lift that I am usually parking my car on and would like to know if that will work with the 2015 Z06?
Surprisingly, I cannot find it anywhere on GM site...
I have asked foir the same on the C7 forum but got the measurement for the C7 not for the Z06... ;-)
Many thanks in advance
Phil
The problem with the C7 is the cradles are no longer square, flat, and even. Only the rear portion of the front cradle is flat. Even at the ends of the cradle where the a-arms mount the surfaces are different heights or angled. It would be best to have the car on a lift so the adapter contact points could be fitted to to the cradle.
Despite it being below zero I ran out to the shop and snapped a couple pictures. Those who have not been under their car may find them interesting. This is a Z51 but all the structure is the same on a Z06. Here is a side view of the rear. Notice how nothing is flat or level like previous generations. The probable contact point for an adapter is circled. While this is on the rear section, the frame mount is just above. Gm suggests the center of the front section.
This view shows the shape of the rear cradle. If your OCD the contact point is angled.
About 21" outside edge to outside edge.
The front is more complicated. The rear section is flat for the most part and a support across it would be easiest, but a large rubber pad on the jack would be enough. Trying to lift at the outer edges of the rear section gets difficult as there is no simple contact point. It is a long reach from the front to get the jack to the rear section.
Circled in green is a possible spot for an adapter, it is on the front portion of the cradle next to the a-arm and is supported to the frame.
Again, nothing is flat and even. The front ear is lower then the back but should be fine doing the job by itself.
Outside measurements, just inside of the alignment washers is about 26.5 " I would not construct a lifting adapter without having the car there to custom fit. It just is not as simple as it used to be.
Safely jacking either front only or back and front
http://netwelding.com/Jacking_A_C7.pdf
